Old 05-01-2009, 03:07 PM   #1
STI_FFY's Avatar
STI_FFY is on a distinguished road
Xenarc 702TSV torn flex cable after custom fit
I bought a 702TSV to replace the old Lilli in my Subaru's dashboard. The reason for the replacement was that the old Lilli was never very easy to see, and the touchscreen has started to fail lately. Sometimes touching the screen does not move the pointer at all or moves it to a point very far from where touched.
The 702TSV is incredibly bright and all my testing so far shows it to be far better than the original Lilliput (which was not transreflective).
Of course I had to modify the display to fit it into the double-din opening in my STi's dash. Now the Xenarc LCD panel snaps into the STi dash from behind.
Anyway, after taking it apart many times and putting it back together for intermediate testing, it failed the test yesterday. The colors were all screwed up. I first verified that this affliction applied to all 3 sources - VGA, AVI2 and internal menus. The most likely candidate for this collection of symptoms was the flex cable.
It turns out that in the disassembly process I overstressed the flex cable that connects the controller to the LCD panel. It has a short tear through pins 1-4 of this 50-pin flex cable.
Be careful with that cable! It cannot be replaced apparently. I had to buy a new LCD panel @ $190 plus shipping in order to fix this.
Fortunately for me Xenarc are very good about selling parts.
It's very sad that now I have this perfectly good and very bright LCD panel that cannot be used for want of a few conductors on this cable. If the other end was removable this would be a $10 fix.
I tried to repair this by jumping the gaps with fine wire, but there's no soldering tip on earth thin enough for this job - at least not when wielded by me.
SeeYa! -Jim-
STI_FFY is offline   Reply With Quote
Old 05-01-2009, 03:49 PM   #2
SwiftDeath's Avatar
SwiftDeath will become famous soon enoughSwiftDeath will become famous soon enough
Wow that's rough. I suppose it's good you posted this as it's good to know how strong, or in this case fragile, certain components are.
-SwiftDeath
SwiftDeath is offline   Reply With Quote
Old 05-01-2009, 06:56 PM   #3
STI_FFY's Avatar
It seems to be very difficult to slide the cable out once the black plastic bail has been lifted on the connector. With no pull tab or block on the cable it is necessary to pull on the cable itself. It is difficult to pull without exerting uneven pressure and one end of the cable will get stressed.
When the new one arrives, I will consider gluing a pull block onto the cable so it will be easier to get it out of that connector when need be.
SeeYa! -Jim-
Old 05-01-2009, 07:17 PM   #4
PaulF's Avatar
PaulF is on a distinguished road
Have you tried shaving the plastic off of the wires? If you used a knife and shaved the plastic off of the ribbon in that spot, you might get enough room to solder it.
My Car (Just the audio install as of now)
http://paulfurtado.com/car/
Worklog:
http://www.mp3car.com/vbulletin/work...-work-log.html
Planning 90%
Computer Build 88%
Programming 10%
Car Install 71%
PaulF is offline   Reply With Quote
Old 05-01-2009, 07:25 PM   #5
STI_FFY's Avatar
The insulation isn't the problem. The spacing between the wires is.
I got the copper exposed using an emery board. I actually managed to bridge pin 1, but when I tried to bridge pin 2, the bridge on pin 1 came undone (the iron touched it briefly). Also the jumper wires are so short that when you touch one end, both come unsoldered and the wire shifts.
I suspect the only way to be successful would be to have several wires spaced the correct distance and solder them all at the same time. I have not yet come up with a way to do this.
I haven't given up. I've thought about taking an old surface-mount chip and using its legs. I'll need to find one with the right spacing and long legs.
SeeYa! -Jim-
Old 05-01-2009, 07:30 PM   #6
colin's Avatar
colin will become famous soon enoughcolin will become famous soon enough
Try using solder paste and a heat gun on very low air pressure on just that spot. The syringes that they provide you with are ridiculously small and with wet enough solder you could fix that for sure. If not, sell it to me for super duper cheap and Ill make it work
2001 Mustang Convertible Worklog
Indigo Custom Frontend (Flash/Delphi)
Blog
Code:
Currently: - Working on my new product! Wiring: |■■■■■■■■■■■■■■■■■■--| Trunk: |■■■-----------------| Sound: |■■■■■■--------------| Screen: |■■■■■■--------------|
colin is offline   Reply With Quote
Old 05-01-2009, 08:47 PM   #7
STI_FFY's Avatar
I think the problem with that approach would be lack of structural strength. The moment it flexed the solder would crack. You need some wire across the tear for rigidity.
SeeYa! -Jim-
Old 05-01-2009, 09:00 PM   #8
colin's Avatar
Well im assuming the black (darker) part doesn't flex? I would just coat that part in epoxy and not let it flex. There's no way that a 1mm difference in where the cable can and can't flex would affect performance. Youd basically just be extending the rigid connector area.
Blog
Code:
Old 05-01-2009, 09:49 PM   #9
mrbean_phillip is on a distinguished road
Would you consider selling that LCD then? I could fix it, and have a need for just an LCD -> will run LVDS onterface off my motherboard to it...
Would appreciate your feedback.
mrbean_phillip is offline   Reply With Quote
Old 05-01-2009, 11:28 PM   #10
STI_FFY's Avatar
I'm not really interested in selling it. I plan to devise some way to fix it. It may take some time, but there's got to be a way.
SeeYa! -Jim-
Old 05-02-2009, 12:14 AM   #11
nobb will become famous soon enoughnobb will become famous soon enough
Have you looked into getting a silver solder pen? I have no experience with them, but it would probably be easier than soldering.
nobb is offline   Reply With Quote
Old 05-02-2009, 02:34 AM   #12
rodweb is an unknown quantity at this point
Is the cable plugged in at both ends or is the other end permanently connected?
Perhpas you could be looking for a new cable. There is a seller on eBay called RaidGear (from memory) who I bought a ribbon extender for the buttons on the 706TSA.
RodW
2007 Toyota Hilux with a CarPC..
Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
rodweb is offline   Reply With Quote
Old 05-02-2009, 03:32 AM   #13
Ah, no worries.
Thx anyway, and goodluck with it
Old 05-02-2009, 04:38 PM   #14
STI_FFY's Avatar
I don't think so. I've not taken the backlight/LCD assembly apart yet, but I probably will eventually. The flex cable becomes as wide as the assembly at the top, and disappears into the full width of that assembly. There is a piece of tape over top of the opening through which it passes. I am imagining that the LCD panel (minus the backlight and houusing) has this cable permanently attached to its top edge much as the touch panel does.
Xenarc have removed the ID label from the back of this assembly so I can't tell who manufactured it.
SeeYa! -Jim-
Old 05-02-2009, 04:41 PM   #15
STI_FFY's Avatar
Although this is an interesting idea, I think it won't work because the tear does not fit perfectly back together. The edges of the tear curl a bit. There is nothing in the gap on which to draw. If I made an epoxy extension of the stiff portion of the flex cable (where the contact fingers reside) to just beyond the tear, I might be able to do this. It's worth considering.
SeeYa! -Jim-
alternator whine though video composite cable on xenarc 700idt? barbarianbeast LCD/Display 8 04-29-2008 08:56 PM
xenarc ribbon cable villybhakta LCD/Display 0 06-18-2007 03:24 PM
FS - Custom made Xenarc Bezel for 05+ WRX/STi RR BuGGz Classified Archive 0 09-13-2005 03:33 AM
WTB LCD/TFT monitor that will fit in xenarc shroud lostreception Classified Archive 2 08-17-2005 01:51 PM
Does Xenarc use a DFP to VGA cable? Player_One LCD/Display 3 11-08-2004 04:27 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
