Extreme Power Backlight for LCD – Read Text under Direct Sun convertibles Sunny LCD
Hey all,
Ive herd many ppl having trouble with direct sun hiting the screen and you can read text on it. If you happen to have a convertible then its huge problem for summer driving. Transflective layer seam to help a bt but not much. So i decided to start my project called Sunny LCD to try to do DIY LED backlight that will have enough power to see text or GPS in convertible or when sun falls on the screen through the sun/moon roof.
Simple idea is to use high power flash LEDs (those that are used in police cars as their white siren lights)
Bigest one I can find is 3W 50,000 lumens (for comperison 100W incadecent light balb has 1500 lumens). I say if i use 4 such LCDs i will get 200,000 limens that is technucally so bright that you cant look at it (we can reduce sight intencity at night =)
Biggest problem will be heat. About 200C is closed box, so if i can figure proper radiator we are good to go. Or we can yse our car as owen as on the go amlet maker =)
So if you interedted in the project drop me the line here or tell me your thoughts. I will need to rise few bucks in donations to afford all parts for experiments. Also if you got spare monitor I can take that. So far I only got extra TM-868 but it broke alredy. I also bough 1 unit of 1W LED that i will test drive tonight when i get powersource ready for it. For now just will postr pix of this LED. its exacly the same one as used in NYS traffic signs.
