Notices
Old 03-11-2003, 06:48 PM   #1
increasing resolution, hows it done, do I get it?
I just got a xenarc screen, ordered yesterday, but about 3 days ago xenarc site said the screen di 1280x1024, and now it says it does 1600x1200. the price is not changing...
so what screen did I get? stuck with the first one? or can it be upgraded to the higher resolution? just confused on how max resolution can change day to day...
ares is offline   Reply With Quote
Old 03-12-2003, 01:55 AM   #2
why don't you just contact them and find out?
AHLU is offline   Reply With Quote
Old 03-12-2003, 01:59 AM   #3
I'm sorry, and you are....?
frodobaggins's Avatar
what would be the point ? The screen has physical resolution of 800x480. Anything you run on it is not going to look any better at 1600x1200 as it is at 1280x1024
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 03-12-2003, 06:38 AM   #4
Does it?
I got the impression from some pics that were posted a while ago that the res of the panel had been changed as well?
Dave
thenominous is offline   Reply With Quote
Old 03-12-2003, 07:42 PM   #5
The native resolution still says 800x480. There is probably a built-in video scaler like the ones found in a plasma display that makes the 800x480 LCD display all the way up to 1600x1200. However, at 1600x1200, so many pixels get dropped that you won't even be able to read anything. 1600x1200 or 1280x1024? It doesn't even matter because you are not gonna use those two resolutions on a 7-Inch screen anyways. 800x480 native resolution is really high though. That is equivilent to 2400x480 if you use the same method that many other companies use to state pixels. When you see a 7-Inch screen with a 1440 x 234 resolution (for example, the popular TM-701L that digitalww sells), it actually has a native resolution of 480 x 234. They are counting each sub-pixel (R,G,B) as seperate pixels. Why are companies doing this? Well... because consumers like to see high numbers.
jza80 is offline   Reply With Quote
Old 03-13-2003, 12:02 AM   #6
Quote:
Originally posted by thenominous
Does it?
Dave
well a 1600x1200 screen at 7" would probably cost somewhere around $3000 or more
[H]4 Life
I'm a lesbian too.
I am for hire!
