Old 06-02-2009, 09:16 AM   #1
BradP is an unknown quantity at this point
Amperage for Lilliput 10.4in Monitor
Hello
I need a power adapter for a Lilliput FA1042-TV/C/T monitor but can not find the required amperage for it. I know it is a max of 13w at 12v DC but no specs tell me the amps.
BradP is offline   Reply With Quote
Old 06-02-2009, 10:43 PM   #2
It ain't easy being a green moderator
meddler's Avatar
Location: Steps out the front of Henson's workshop or Sydney
meddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud of
well if the max is 13w, then you can work it out.
P=VI (power = volts x amps)
13w = 12v x I
I = 13 / 12
therefore the current required is just under 1.1 amps
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
meddler is offline   Reply With Quote
Old 06-03-2009, 07:26 AM   #3
Thanks for the reply. I must have forgotten that formula from my high school physics days
I found a site after, the only site I could find, that says what the amperage is for that monitor.
http://smallandquiet.blogspot.com/20...creen-lcd.html
being 1.5A or 1500mA. Apparently most, if not all, Lilliput monitors use the same power supplies.
Old 06-03-2009, 09:00 PM   #4
meddler's Avatar
no worries, glad you found what you needed.
Help needed RGBS monitor - needs VGA input Zductive LCD/Display 15 10-13-2007 05:50 PM
FS: Dynamix 8.4" 816 Widescreen Touch Screen Monitor tn6478 Classified Archive 12 03-18-2007 02:52 PM
Carnetix Fried Monitor ViViper1 Power Supplies 0 11-26-2006 12:38 PM
Small Monitor Suggestions? rdunajewski LCD/Display 3 08-02-2005 07:24 PM
Running windows with no monitor? BLACKOUT General Hardware Discussion 14 03-14-2001 11:56 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
