Old 06-03-2009, 05:38 PM   #1
kuo
kuo's Avatar
kuo
help wiring a capacitor to filter noise
with the help of the information in this thread i successfully hooked up my xenarc's brightness control wire to my car's dimmer knob. because my car's dimmer knob outputs from 0V to 12V and the xenarc's brightness control wire only goes from 0V to approximately 3.7V, i wired up a voltage divider to get into the desired range as follows.
the problem i have after doing this mod is that i get rolling lines in the screen whenever i dim the backlight using the knob. when i dimmed the screen using the lcd's menu i didn't get lines. Also the interference was present before i wired in the resistors, so the interference is definitely coming from the knob. i tried to wire up a capacitor to filter out the noise but i had no idea what i was doing and all i did was screw things up so i took the capacitor back out. i've done a lot of googling and reading here on the forums for guidance on how to do this but i'm still at a loss. can anyone tell me if i'm even on the right track with the capacitor idea, and if i am, what kind of capacitor do i need and where do i put it into the circuit? when i tried to wire it in, the dimming did not work at all and stayed at full brightness with output at 0V so i was obviously doing it wrong.
my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
kuo is offline   Reply With Quote
Old 06-03-2009, 06:05 PM   #2
Sicarius is on a distinguished road
Is your dimmer really outputting a lowered voltage or is it pulsing the output (ie. producing a square wave with varying duty cycles)?
Sicarius is offline   Reply With Quote
Old 06-03-2009, 10:16 PM   #3
kuo
kuo's Avatar
kuo
how would i go about figuring that out?
i was also thinking...i have one of those noise filters from radioshack. could i wire that into the circuit somehow?
Old 06-05-2009, 10:53 AM   #4
kuo
kuo's Avatar
kuo
so i got some smaller ceramic caps wired in but i still have noise. i'm stabbing in the dark here since i know very little about the physics involved in all of this but my next move is to try bigger resistors in my voltage divider. i'm thinking since this is just a signal wire maybe i've got too much juice flowing...
Old 06-05-2009, 12:10 PM   #5
Pathos's Avatar
Pathos is on a distinguished road
Is your dimmer the rheostat type or is it digitally controlled?
"A rose by any other name is still a flower"
Pathos is offline   Reply With Quote
Old 06-05-2009, 04:31 PM   #6
Which is the same question I asked and it really needs to be answered.
If it's a rheostat lowering the voltage then you should be good and won't need a cap.
If the output is pulsed, then no amount or type of capacitor will do what's requested.
Old 06-08-2009, 09:40 AM   #7
kuo
kuo's Avatar
kuo
i have the service manual for my car but it doesn't say anything about the dimmer being a rheostat. i googled for a while and found a few instances of people calling the dimmer a rheostat but nothing definitive...could be people just making assumptions. is there a way to test the dimmer to see if it is a rheostat or not? i have a cheapo multimeter.
Old 06-08-2009, 01:07 PM   #8
colin's Avatar
colin will become famous soon enoughcolin will become famous soon enough
For the most part, dimmers in cars are simple rheostats with voltage from 0-12v measuring in 255 bits. Your car actually knows how far your dimmer is turned, although it doesnt need to.
The xenarc display is probably using a square wave pulse to control the lighting. Both LEDs and CFFLs are hard to control with varying voltage.
2001 Mustang Convertible Worklog
Indigo Custom Frontend (Flash/Delphi)
Blog
Code:
Currently: - Working on my new product! Wiring: |■■■■■■■■■■■■■■■■■■--| Trunk: |■■■-----------------| Sound: |■■■■■■--------------| Screen: |■■■■■■--------------|
colin is offline   Reply With Quote
Elminating line level noise spoonraker General MP3Car Discussion 1 12-20-2006 03:23 PM
Noise Problem(Yes I saw the sticky) diablodemorte Car Audio 8 10-04-2006 06:16 PM
Noise from my inverter .. Filter ? Frog_boy Power Supplies 1 08-14-2006 06:23 AM
need some noise help spyhunter General MP3Car Discussion 6 07-20-2003 11:20 PM
Specific wiring schematic 4 Optrex DMC40457? sooty LCD/Display 9 07-17-2001 03:11 AM
