Old 06-08-2009, 02:04 AM   #1
fatejd is on a distinguished road
Vertical lines on screen
Tonight I finally got around to taking my screen mount off my car to do some maintenence to the bracketing I have around the screen to keep it in place and ever since I did that I have this 1/4 section blacked out and with vertical lines. The lines have changed places at least once since this happened, but I can't figure out what is causing this issue. Does anyone have good ideas? I tried messing with almost all the wires on the screen with no change. I don't think I even touched any of the controllers when this happened - maybe it touched something and got shocked?
Carputer Progress:
Re-do fabrication of screen [DONE]
Upgrade screen and PC [70%]
Wood faceplate for computer in glovebox [0%]
fatejd is offline   Reply With Quote
Old 06-10-2009, 12:53 PM   #2
Here are a couple more pictures - first is of the entire back with a couple of the controller boards removed, the second is of what I think is the affecting portion of the cable to the LCD...
Carputer Progress:
Old 06-11-2009, 01:36 AM   #3
I think this problem may be due to one of the cables being loose between the screen and the VGA cable - will try and remedy it tomorrow.
Carputer Progress:
Old 06-11-2009, 06:03 AM   #4
mcfly's Avatar
mcfly is an unknown quantity at this point
I'm sorry to tell you, but it's beyond repair.
From my worklog:
Quote: Originally Posted by mcfly View Post
At the first mock-up, I successfully f*ed the monitor. I somehow managed to press some screws against two of the flexible PCBs that carry data to the panel itself. This left two, multiple pixels wide lines on the screen:
I looked under microscope, and the broken circuits that should be reconnected, are 20 microns wide, several times narrower than the tip of a needle.
You can't even replace the damaged flexible circuits, as they are glued to the glass.
mcfly is offline   Reply With Quote
Old 06-11-2009, 08:21 AM   #5
sargeants's Avatar
sargeants is an unknown quantity at this point
^ditto - well no microscope, but it is the actual screen - and not something you can deal with by hand
start looking for a new screen
03 Hyundai Elantra GT
HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
RideRunner; cmdRR tall skin (in creation)
Elantra Worklog
86 Pontiac Fiero SE 2m6
Sony MP3 CD deck
eventual carpc install
sargeants is offline   Reply With Quote
Old 06-11-2009, 11:28 AM   #6
Yeah, I already started doing that - thought it was busted, but thought I would give it a shot anyway. Good thing there is a Xenarc 10.2" widescreen now that should work
Carputer Progress:
FS: Xenarc 700TSV Touch Screen Monitor VYR8 Classifieds 0 01-18-2009 12:21 AM
Help. Lilliput 619. white screen/rainbow vertical lines. Kevin22 LCD/Display 1 10-12-2008 06:42 PM
Tedelex LCD Screen ryanbyn01 LCD/Display 3 09-05-2007 09:46 PM
Blue Devil Skin RELEASED JohnWPB RR Skins No Longer Supported 1005 01-05-2007 08:54 PM
Motorized Flip-Up Screen Ideas? DryBear Fabrication 10 01-16-2006 02:09 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
