Old 06-14-2009, 03:48 PM   #1
danimal is an unknown quantity at this point
Hacking a 120vac monitor?
Has anyone hacked a LCD Monitor with an internal power supply such as this one to bypass the internal power supply and run 12 vDC?
http://http://cgi.ebay.com/ELO-15-in...3A2%7C294%3A50
danimal is offline   Reply With Quote
Old 06-14-2009, 04:27 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Sure it's possible. But is it practical?
You have to ask yourself where you're going to put a 15" monitor in your ride.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 06-14-2009, 06:52 PM   #3
right in the middle of my dash, i have a quadruple din space to work with
Old 06-14-2009, 06:59 PM   #4
North of the land of Hey Huns
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
It probably needs regulated 12vdc so you can't power it off regular car power.
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
malcom2073 is offline   Reply With Quote
Old 06-14-2009, 08:47 PM   #5
Fix your lnk.
And I agree with malcolm. It very likely requires regulated 12vDC.
Can the AC-DC converter be removed or bypassed? Possibly.
Personally, I think it would be easier to find a touchscreen that uses a "power brick". That power brick handles the AC-DC conversion.
With a setup like that, you can simply provide the proper regulated voltage and call it a day.
I know for a fact that such touchscreens exist. I have worked for companies that resell them.
(Before you ask - no, I don't have a line on them any longer.)
What kind of vehicle has the dash space for a 15" monitor? Are you driving a Peterbilt or something?
Old 06-14-2009, 09:46 PM   #6
Deric's Avatar
Deric is an unknown quantity at this point
I personally would look for one of the newer ELO's that use the 12V adapter if you are set on something this big. We have several of these units at work and the older ones (like in your link) reflect the sun like a mirror. The newer style ones don't show glare as bad. If I had the amount of space as you I would get a 10.4" screen and use the additional space for a slot load DVD drive.
Deric is offline   Reply With Quote
Old 06-14-2009, 10:03 PM   #7
PaulF's Avatar
PaulF is on a distinguished road
Anything is possible with some hackery. How good are you at making/figuring out circuits?
My Car (Just the audio install as of now)
http://paulfurtado.com/car/
Worklog:
http://www.mp3car.com/vbulletin/work...-work-log.html
Planning 90%
Computer Build 88%
Programming 10%
Car Install 71%
PaulF is offline   Reply With Quote
Help needed RGBS monitor - needs VGA input Zductive LCD/Display 15 10-13-2007 05:50 PM
FS: Dynamix 8.4" 816 Widescreen Touch Screen Monitor tn6478 Classified Archive 12 03-18-2007 02:52 PM
Carnetix Fried Monitor ViViper1 Power Supplies 0 11-26-2006 12:38 PM
Small Monitor Suggestions? rdunajewski LCD/Display 3 08-02-2005 07:24 PM
Running windows with no monitor? BLACKOUT General Hardware Discussion 14 03-14-2001 11:56 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
