Old 06-22-2009, 04:13 PM   #1
nohope is an unknown quantity at this point
BUG cannot use a flash disk while touchscreen usb is connected!!!...help
hi all
i need help in this
i haved a d945gsejt mobo
2gb ram
cid700m in dash 7"lcd vga touchscreen usb
i installed the drivers the touchscreen works fine but when i try to connect a usb-flash disk or a usb-dvd the computer says it is an unrecognized device while if i disconnect the touchscreen usb , the windows reads it normally
cant get y?
any ideas??
help please
nohope is offline   Reply With Quote
Advertisement Sponsored links
Old 06-22-2009, 05:27 PM   #2
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
Not enough power. Are you connecting these to an unpowered hub?
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
Old 06-23-2009, 12:52 AM   #3
no it's connected directly to the motherboard
Old 06-23-2009, 02:39 AM   #4
Crinos is an unknown quantity at this point
Basically the same then... Some MOBOs use "unpowered hub" principe on the USB "hubs" connected. Strange, since it's easy to give the 5V needed...
If you try with a powered USB hub, your problems should go away
Crinos is offline   Reply With Quote
Old 06-23-2009, 02:46 AM   #5
Smile
i will try & reply on this thread
thanks
Old 06-23-2009, 10:48 PM   #6
Curiosity's Avatar
Motherboards should be able to produce 500mA continuous to all ports at the same time. But don't rule out other possibilities. You're describing problems with high power devices, but they are also USB 2.0 bulk transfer and the touchscreen is probably 1.1 so that's another factor. You could also be taxing the PSU. An external hub is still a good place to start though.
USB Flash drive preventing hibernation Zysen WinNT Based 0 01-16-2009 12:08 AM
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 12:49 PM
usb flash drive issues?? djmickyg Hardware Development 4 08-27-2005 11:27 PM
Need help with installation of Usb touchscreen Software doddyz LCD/Display 2 08-23-2005 07:11 AM
FS:Brand New SanDisk 256MB Cruzer Micro USB Flash Drive kickercivic1 Classified Archive 3 08-04-2005 02:16 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
