Old 06-24-2009, 06:45 PM   #1
coastaldamage is on a distinguished road
Cool Brightness control on Xenarc 700TSV
Has anyone found out how to control the 700TSV's brightness with the car? I was thinking about tying into my car dimmer switch.
coastaldamage is offline   Reply With Quote
Advertisement Sponsored links
Old 06-24-2009, 06:55 PM   #2
kuo
kuo's Avatar
kuo
did just that a few weeks ago. see this thread. This is the thread that got me started. your wire colors may vary. mine was orange.
my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
kuo is offline   Reply With Quote
Old 06-24-2009, 09:27 PM   #3
Have you managed to get all the bugs worked out?
Old 06-25-2009, 10:42 AM   #4
kuo
kuo's Avatar
kuo
yes i used bigger resistors and added a few smoothing caps and the interference is gone. very happy with the results now.
Old 06-25-2009, 03:33 PM   #5
Can you show me what you used and how to hook it up?
Old 06-30-2009, 08:25 AM   #6
kuo
kuo's Avatar
kuo
i would first measure the output of your dimmer knob. more than likely it goes from 0V to 12V. If this is this is the case you can make a voltage divider as shown in the post i linked above. the lcd controller board sends from 0 to around 3 or 4V down the backlight control wire depending on what the backlight level is set to. you basically cut that wire the end going into the inverter to your car's dimmer knob. i used a 20k and 10k ohm resistor with a diode in front to make my voltage divider. i also added a few small ceramic capacitors. my interference issues went away after increasing the size of the resistors but the caps may be helping too.
Old 06-30-2009, 08:35 AM   #7
joshuo is an unknown quantity at this point
Could you just put a variable resistor in line with the backlight?
joshuo is offline   Reply With Quote
Old 06-30-2009, 09:10 AM   #8
kuo
kuo's Avatar
kuo
most cars use a variable resistor (rheostat) for the dimmer knob, but i think the point here is to tie the screen brightness to the brightness of the dash lights. this way, when you turn your headlights on, your screen's backlight dims along with your dash lights. imho having a separate dimmer knob for the screen is only marginally better than using the osd to dim the backlight.
Old 06-30-2009, 10:28 AM   #9
good point.
Alternatively, is there a way to have the up and down arrow buttons change the brightness instead of volume on the 700TSV?
Old 09-24-2009, 03:57 AM   #10
What I thought about doing, but have not had a chance to test it yet, was to use another variable resistor(potentiomitor parden my poor spelling) and setting it to where the output ranges from 0-3.4 in direct relation to 0-12. This would allow me to use it on a different screen, or possible something totally different.
Xenarc 700tsv bsod? help. Cerztrueheart LCD/Display 8 03-06-2007 07:57 PM
Xenarc 700TSV Doesn't Fit zzzBrett LCD/Display 7 01-30-2007 03:13 AM
Xenarc 700TSV, Xm Direct, etc for sale Zinjamaster Classified Archive 7 10-02-2006 08:57 AM
FS: Xenarc 700TSV touch UXGA capable cproaudio Classified Archive 16 01-20-2003 07:38 AM
