Old 06-28-2009, 04:04 PM   #1
scsirob is on a distinguished road
Transflective Lillyput - Touchscreen trouble
I have one of the very early Lillyput transflective screens (Jan. 2006), bought one when they were just released. The screen works great, but the touch continues to be flakey. Even the slightest pressure on the front of the case makes the mouse jump around erratically.
The early versions were known to have this issue. I sorta fixed it by running a wire along the sides of the touch panel, to act as a spacer. This worked a bit but not reliably.
The only remaining option I can think of is to cut a little bit off the touch panel so none of the sensitive area can get in contact with the case anymore. Has anyone ever done this before? Can this be done or will this ruin the touch panel? It's a 4-wire resistive type. Hints and tips are welcome...
As yet another alternative, would the components of this monitor fit inside a double-din conversion frame?
scsirob is offline   Reply With Quote
Lilliput 629 (transflective) touchscreen problem jbradshw Input Devices 8 12-03-2008 05:03 PM
629GL-70NP Vs Mp3Car 2008 7'' Transflective LED Backlit Sunlight Readable Touchscreen ricbw2 LCD/Display 0 07-27-2008 06:13 AM
lillyput touchscreen problem Leegsi Input Devices 7 11-07-2006 01:40 AM
Touchscreen Trouble, could it be the drivers ? Cruznlife1 LCD/Display 2 07-16-2006 01:14 PM
FAQ: Transflective Technology nameeri LCD/Display 0 06-06-2006 11:26 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
