Old 03-26-2003, 04:53 AM   #1
PTCruiser's Avatar
PTCruiser is on a distinguished road
Talking EPIA M9000 & TM701 =>Problem Fixed
I just hooked up my digitalww screen to the EPIA M9000...
I show the BIOS post on the digital screen booting....
Until windows then I get no signal on the LCD...
On the driver I get the TVout grayed
Impedance problem?
Will try to put the latest bios/Driver on my EPIA...
Anyway the LCD work fine with the mini camera!
Reversed image feathure is great! Thanks Armen
EDIT:
After some research on this board I think v.... where to get it? How to to it...
Solution: (Thanks netsuo)
I upraged the EPIA M9000 with the latest BIOS (TV+CRT in the same time)
I pluged a regular TV on the TVout RCA.
The option is then enabled and this time I get a propetries BOX!
So I putted PAL/Composite Output
And then I get a picture on my TV & my CRT...
Iremoved my RCA from my Regualr TV => plugged it back to the Digitalww screen and It work...
Of course I can shutdown the PC reboot.. the LCD work now all the time...cool!
Epia M9000, lili 7" vga&touch & 2xTM-7002S compo, camera with reversed image, 2.5" 60 GB, 256Mb DDR, Opus 90W, GPS usb... AND MEDIACRUISER of course!
PTCruiser is offline   Reply With Quote
Advertisement Sponsored links
Old 03-26-2003, 05:12 AM   #2
PTCruiser's Avatar
Sorry for this lammer Post
http://www.mp3car.com/vbulletin/show...+Ohm+RCA+cable
I'll try a 75 ohm RCA cable...
Old 03-26-2003, 10:30 AM   #3
lbk
lbk
Do you have a monitor hooked to it at the same time?
I have an EPIA M series, and you cannot do dual display. If you want the TV Out to show you have to disconnect VGA and boot.
lbk is offline   Reply With Quote
Old 03-26-2003, 11:50 AM   #4
PTCruiser's Avatar
Still not working....
I also tried ewith only the tvout and no vga connected => Same result...
When I go to windows nothing anymore on the LCD...
I tried the 75 ohm trick...the tvout is enabled but nothing happen when I am in windows...
Anyway another french member as got a EPIA M + Digitalww screen working! I'll check with him
Old 03-26-2003, 12:08 PM   #5
Registered User
richone
Check the motherboard jumper for S video vs Composite video. I had to move my jumper to display video from the composite port.
Play Well
http://www.robotthoughts.com
My Car
My Interface
richone is offline   Reply With Quote
Old 03-26-2003, 01:19 PM   #6
Mikesz's Avatar
Mikesz
Quote:
There is also a jumper to set the rca out between video and digital audio out.
mike
91 cadillac sedan deville, winXP, FV25 with Celeron 800, Redant 7" widescreen in dash, Opus DC-DC, Irman, Digital Cable remote(lots of buttons), 120 gig 7200rpm 8meg cache WD hard drive, VI power mobile HD rack, mediaengine
Mikesz is offline   Reply With Quote
Old 03-26-2003, 04:20 PM   #7
Registered User
richone
Quote:
mike
That's the same one. It toggles the RCA port between composite and digital audio not s-video and composite...my bad.
Play Well
My Car
My Interface
Old 03-26-2003, 10:11 PM   #8
samc's Avatar
samc
ahh this problem.
If you want it on the monitor, hook up the monitor only and reset.
If you want rca-out, then rca plug only (not vga) and then reset.
Sucks doesnt it.
Mine needs to be updated.
samc is offline   Reply With Quote
Old 03-27-2003, 04:24 AM   #9
PTCruiser's Avatar
Fixed....
Old 03-28-2003, 11:29 AM   #10
digitalww's Avatar
digitalww is on a distinguished road
Quote:
Originally posted by PTCruiser
Fixed....
I am glad you got everything working.
Armen
http://www.digitalww.com
digitalww is offline   Reply With Quote
Old 03-28-2003, 02:43 PM   #11
PTCruiser's Avatar
Hi Armen,
You monitor are so great
Picture quality for composite screen is amazing...
Thanks for your help of www.divx-car.com member!
(a member CruiserLtd wanted his screen ASAP hope you can send it one fast...)
Almost every active member had a screen from you! Hope there will more and more euro buyer for you!
And the tiny camera with reversed image is cool! (I added a wide angle objective on it)
PTcruiser
