Old 03-26-2003, 08:39 PM   #1
BlueVisor
good deal on a 10 inch LCD
http://www.softwareandstuff.com/h_mon_unisys105lcd.html
Unisys brand, requires a special PCI card, no external power needed, $99
BlueVisor is offline   Reply With Quote
Old 03-26-2003, 09:16 PM   #2
bosstone74's Avatar
bosstone74 is on a distinguished road
those are poop! very low nit! (not bright)
BossTone74
bosstone74 is offline   Reply With Quote
Old 03-27-2003, 05:27 AM   #3
hardware_dave
The display they come with are crap , but I have had the 16 bit ISA version running a number of diffrent lcd's. You have to modify the bios (eprom programmer and eraser needed) and the card.
Dave
hardware_dave is offline   Reply With Quote
Old 04-15-2003, 06:22 PM   #4
churnopol's Avatar
churnopol
It's not bad if you dont plan to play dvd's or divx
And i didn't have to cange the bios on mine. And it has the best viewing angle for an STN lcd
churnopol is offline   Reply With Quote
Old 04-16-2003, 12:02 AM   #5
I'm sorry, and you are....?
frodobaggins's Avatar
frodobaggins will become famous soon enoughfrodobaggins will become famous soon enough
Quote:
Originally posted by churnopol And i didn't have to cange the bios on mine.
You only have to do that to use other lcds with the card
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 04-16-2003, 10:31 PM   #6
98explorerxlt
Is it possible to add a brighter backlight too it or worth it
98explorerxlt is offline   Reply With Quote
Old 04-17-2003, 12:13 AM   #7
ddt
Registered User
ddt's Avatar
ddt
it's been discussed at length.
Simply put if it had a low contrast ratio, brighter backlights will just wash out all the color. You end up with a bright LCD you can't see anything on. The other option? Leave it alone and have a dark LCD you can see nothing on.
ddt is offline   Reply With Quote
Old 04-17-2003, 01:46 AM   #8
churnopol's Avatar
churnopol
it has adjustable brightness controllers. I'll say it again, this is the best STN lcd monitor (but it's nothing like TFT). I use it for my carputer. The base and neck are also easy to remove. I've never had a brightness problem. But i keep it next to my arm rest. The only regret is the screen is too big. And you cannot use any other video card, it doesn't use VGA cables, it uses MDR-32. Nor does it use a VGA signal, it uses OpenLDI. Read my posts on the links below. I'm not getting into that again.
Check out all the research i did, and my review on this monitor
http://www.thisstrife.com/uberforum/...081&ForumUID=8
http://www.thisstrife.com/uberforum/...030&ForumUID=8
The reason its the best STN monitor because it uses OpenLDI instead of VGA. But the 4 meg pci card limits it abilities. There's 2 other cards out there that support OpenLDI, there well over $600
If you really have doubts goto
www.mp3playerstore.com
They gaurantee the lowest prices on lcds. Also gives specials to Paypal customers
Old 04-17-2003, 01:02 PM   #9
98explorerxlt
guess ill just hafta save up and buy a plasma screen
Old 05-03-2003, 04:59 PM   #10
RoundSparrow
Anyone else trying to use these in a car?
I have mine on a Shuttle SV24 mini PC system with WIndows 2000 Pro. Running CoPilot 2003 GPS...
RoundSparrow is offline   Reply With Quote
