Old 09-21-2009, 05:46 AM   #1
hairyMerkin is an unknown quantity at this point
Using a touchscreen kit/Output NTSC to screen from PC
I have an r34 skyline, non turbo. It came with a factory screen that pops out of the dash, I want to use this.
Can I just get an overlay, and it'll work like a normal touchscreen?
hairyMerkin is offline   Reply With Quote
Old 09-21-2009, 06:38 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
yes.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 09-21-2009, 06:50 AM   #3
So then I can use the screen to display the picture, and the usb overlay to act as the touchscreen part?
How accurate are they?
Old 09-21-2009, 06:53 AM   #4
Yes. That's how the touckscreen overlay works.
As accurate as any commercial touchscreen. The touchkit is identical to what the touchscreen manufacturers use for their products.
Old 09-21-2009, 06:54 AM   #5
Sweet, cheers guys.
Any brands of overlays that are recommended?
Old 09-21-2009, 08:31 AM   #6
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
They all work pretty much the same. There is a difference between resistive and capacitive but a capacitive touchscreen for the car is not very common. Get the resistive one. I've had both 4 wire and 5 wire and don't see the difference. 5 wire is supposed to be "better" but both work identically.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 09-21-2009, 04:50 PM   #7
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
If i understand OP correctly - that won't work! If he/she is trying to control a computer, how is he going to display the computer's output on the screen. If he just want to put a touch overlay on the factory screen to control IT, then what is the touch overlay going to send signals to?
I'm confused by the answers given so far; the way i see it, it won't work at all.
Intel D945GCLF2 Dual Core ATOM
Lilliput 7" 629GL 2008 LED Backlight
BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
M2-ATX Power Supply
RideRunner Front End / Various Skins
Windows XP SP3
treetop777 is offline   Reply With Quote
Old 09-21-2009, 05:12 PM   #8
Bugbyte's Avatar
Good point. He'll need to purchase an interface that allows the PC output (which will most likely need to be in video format) to be shown on the car's screen.
Want to:
-Where is the iBug?
Old 09-21-2009, 07:27 PM   #9
The screen takes an NTSC input. The next question was how I can output that format from a computer? As opposed to PAL output.
Old 09-21-2009, 07:31 PM   #10
North of the land of Hey Huns
malcom2073's Avatar
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
You could get a VGA to NTSC converter, but keep in mind the image is going to be hard to read/not very good quality. That's the nature of trying to display a computer image on a non VGA screen.
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
malcom2073 is offline   Reply With Quote
Old 09-21-2009, 07:34 PM   #11
Looks like I'll just have to replace the screen then
Old 09-21-2009, 07:37 PM   #12
malcom2073's Avatar
You don't HAVE to, it will work it just won't be as high quality as a normal computer screen. I ran a NTSC monitor for a couple years until I finally got a VGA. I could never go back, but it's certainly an acceptable solution.
That being said I believe you should get rid of it, and go for a real monitor
Old 09-21-2009, 07:40 PM   #13
I'm almost positive the current screen is 7" if not close to, so it shouldn't be tooooo hard.
Old 09-21-2009, 09:45 PM   #14
Bugbyte's Avatar
Just remember that if you replace the screen, you now have the opposite problem - how to display the car info on the new VGA screen. It will depend on how your screen gets its input from the car.
Want to:
-Where is the iBug?
Old 09-21-2009, 09:46 PM   #15
malcom2073's Avatar
Yes that begs the question... what DOES the screen in your car display?
Infiniti g35 Double Din Bolt in Kit with the 7" 629 Lilliput Touchscreen? rijotech Newbie 3 09-06-2009 12:13 PM
touchscreen kit at digitalww question tominated LCD/Display 2 10-14-2006 07:28 PM
FS: DennisK VGA Touchscreen LCD Kit lilkeeney Classified Archive 6 03-12-2005 02:51 AM
7" Lilliput for sale NO TOUCHSCREEN CDesigns Classified Archive 11 05-24-2004 10:47 PM
CHEAP touchscreen kit! sweetrobot2k LCD/Display 0 11-05-2003 01:24 AM
