Old 10-09-2009, 01:10 AM   #1
UnusuallyGenius's Avatar
UnusuallyGenius is an unknown quantity at this point
USB to VGA, DVI or HDMI
USB to VGA, DVI, HDMI Adapters, how good are they really?
Do they honestly work for playing DVD's on?
How many is too many? When do you notice performance issues?
Can they really drive a HD screen at say 1080i? (not that I will have 1080i in my truck)
Fear The Griz
-Everything I do is Unusual
-Everything I do is Genius
-That is why I am Unusually Genius
94 Ford Explorer
Acer Aspire One 8" Netbook
-Working On GUI for openMobile
-Unusually Genius Development Website
-Worklog
UnusuallyGenius is offline   Reply With Quote
Old 10-09-2009, 01:58 AM   #2
sergatiuk's Avatar
sergatiuk has a little shameless behaviour in the past
i personally never used one but you should take into consideration that USB devices are processed by the CPU, CPUs are not designed to process/render video. from my experience with linux, a dual core pentium M CPU is capable of playing 720P, 1080i and probably 1080P if my LCD would support it.
when video is processed by the CPU you should expect the CPU to reach very high temperatures as it is being used at 90%-100% capacity. this is how i burnt the fan on my acer lappy.
you also have to consider the fact that while the CPU is processing video the OS would not be very responsive.
the new ION boards might handle this better because this chipset is designed for that purpose.
from my experience a dual core is capable of pushing 1 output, i believe a quad core will push 2, but i doubt it will handle more then that.
2007 Toyota Tundra Double Cab SR5
>"Say what you mean and mean what you say"<
sergatiuk is offline   Reply With Quote
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
Powered USB Hub Anyone? Lukeyson General Hardware Discussion 19 07-09-2009 05:54 PM
Lilliput GL701 VGA usb cable switch to DVI? AJWatU LCD/Display 4 07-15-2007 07:07 PM
Found Cheap Cables: VGA 10ft $6, USB Extension 10ft $2 and More! WarDriver General Hardware Discussion 12 07-13-2006 12:04 AM
Lilliput USB and VGA connections FunkDaMonkMan LCD/Display 1 01-01-2004 09:32 PM
