Xenarc 700IDT interference
Hi,
I've just finished a car PC install in my 1996 Nissan Skyline. I've got a problem though with horizontal lines that flicker through the display, if that makes sense.
This only happens on the PC input, i also run 2 RCAs, one for a Playstation 2 and the other for the DVD input from my head deck. Those seems to be fine.
At first i thought this may be a power issue as the screen runs straight off the cars power supply (not through the PSU). According to the manufacturer it can be run fine like this but i'm thinking of switching to the PSU just to be safe based on most of the posts i've researched here.
However just to test this theory, i plugged the VGA cable into my laptop instead of the car PC and even at the same res and refresh rate - the flicker is gone. It only happens when the VGA cable is plugged into the car PC.
Will running the screen off the PSU help solve this problem? And if not what else could i look at trying? The manufacturer makes mention of adjusting the 'phase' option on the screen (doesnt do much), and also running a power filter (have a 5amp one already wired in).
Thanks for any advice!
