Old 10-20-2009, 01:55 PM   #1
silvi4000 is an unknown quantity at this point
lilliput 619/629 LCD ribbon cable replacement
I need to replace the LCD ribbon cable on a lilliput 619. While searching, most posts recommend buying the cable from http://www.digitalww.com/ . That site seems to be down for around a year now. The rests of the results are pretty much unanswered questions about where to get the ribbon cables from.
Where can I get a replacement ribbon cable for a 619?
Has anyone had any luck modding some other generic ribbon cable to make it work?
silvi4000 is offline   Reply With Quote
Old 10-20-2009, 02:10 PM   #2
chkolny1 is an unknown quantity at this point
the mp3car store itself sells ribbon cables. how many pins on it and how are they spaced apart?
chkolny1 is offline   Reply With Quote
Old 10-20-2009, 02:52 PM   #3
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
You need
.50mm FFC Low Profile Connectors 0.5mm JUMPER 40POS Type D FFC 7.00
There are two types A and D, one has pins same side, the other has the pins reveresed.
http://www.mouser.com/Search/Refine....-21020-0439%09
or
http://www.mouser.com/Search/Refine....-21020-0438%09
This is the page in their pdf, you need to look at the cabels at the bottom right.
http://www.mouser.com/catalog/633/1396.pdf
Enforcer is offline   Reply With Quote
Old 10-20-2009, 11:18 PM   #4
Quote: Originally Posted by Enforcer View Post
You need
or
awesome, exactly what I was looking for.
The links are broken but I'll try to find them using the description
thanks
Old 10-20-2009, 11:38 PM   #5
in my case is same side pins so this seems to be the closest match:
http://www.mouser.com/ProductDetail/...qT1xoAzg%3d%3d
40 pins, same side, 6 inches
Old 10-21-2009, 06:50 AM   #6
Confusion Master
Enforcer's Avatar
thanks
Sorry, that's what you get for just copying and pasting a previous post without actually editing it to get the urls properly.
Links should now be correct.
WTB: 13 connector ribbon cable for lilliput illudezion Classified Archive 0 03-13-2007 01:39 AM
LCD off ebay, replacement connector cable? Xander LCD/Display 2 09-27-2005 09:54 PM
Lilliput 8" ribbon cables? therussman2002 General Hardware Discussion 4 12-24-2004 10:17 AM
