Quote: Originally Posted by
tbird2340
The USB Mouse IS the Lilli: USB\VID_0EEF&PID_0001
The unkown device is ACPI\ATK0110 and I guess that's just a utility for my motherboard.. Still doesn't tell me wth is wrong but does confirm it's the Lilli.
Oh ok, well let's see if we can get the unknown device installed first. That would at least eliminate it from being the problem if you're still having issues with the install. It looks like that item is a system device anyway. Here is an excerpt I found from the following thread that seems to solve the unknown device problem. Ignore the fact that the folder says win2000 but I'm assuming you're running XP.
http://www.velocityreviews.com/forum...-identify.html
It's a ATK0110 APCI Util used for changing the fsb and multiplier under
windows for AI Booster.
Here is how you fix it. this fix works on all Asus A8N-SLI Motherboards,
Basic and Deluxe Versions regardless of bios versions and is for Windows x64
build 1289 onwards. I am running build 1433 RC2 and this still work aok.
Insert your motherboard driver cd or download the latest AI Booster from
Asus.
Browse the cd and goto \software\aibooster\acpi64 and copy the win2000
folder to your desktop.
Open the win2000 folder on your desktop and open the file ATK2000.ini with
Notepad.
Look for this
[Manufacturer]
%ATK%=ATK
[ATK]
%DeviceDesc1%=DriverInstall,ACPI\ATK0110
and change it to this (bold text is only to show you what you have to
change)
[Manufacturer]
%ATK%=ATK,NTamd64
[ATK.NTamd64]
Save the file and then go to the unknown device in device manager and manual
update the driver pointing it to the win2000 directory on your desktop.
There is no need to install the AIBooster software if you aren't going to
use it.
If you attempted to run AIBooster previously it would have errored during
the install of the APCI driver but it will install now aok and run fine.
Drivers now have to be assigned in this way as from build 1289. This mod
will probably work with other drivers that you found that worked on previous
build versions but don't work on the new build version.
That's it done.
Good luck.
StOrMtRoOpEr [HOW] Clan
