Old 10-25-2009, 06:42 AM   #1
tuningmania's Avatar
tuningmania is an unknown quantity at this point
How to extend VGA cable for "Lilliput EBY 701"?
Hi,
How can I extend the original vga cable for my "Lilliput EBY 701"? The monitor is in front table of the car, but the car pc - in the trunk I found this: Click Here but this is scared me:
Quote:
**Note: This cable is not compatible with the Lilliput cables.
I try to put a normal "VGA" cable, in the car pc, that reach the front panel, and in it, I put the original cable of my "Lilliput", but the picture on the "Lilliput" is, or green or blurry (with two different "VGA" cables)
tuningmania is offline   Reply With Quote
Old 10-25-2009, 10:23 AM   #2
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
i just use a regular sheilded vga extension cable. I have no problems
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 10-26-2009, 01:42 AM   #3
chkolny1 is an unknown quantity at this point
just go to your local computer shop and get a vga extension cable, i dont understand the problem
chkolny1 is offline   Reply With Quote
Old 10-26-2009, 08:52 AM   #4
To "chkolny1" - I have 3 different "VGA" extension cables. 1.8 meters, 3 meters and 6 meters. With some of them, the picture on the "Lilliput" is very green! With other - the picture is blurry. Only with the original cable, the picture is perfect! May be the brand of the cables is bad I do not know, what to do..
Old 10-26-2009, 09:42 AM   #5
Terminal flasher
i hate to quote myself.. but
03 Acura RSX Coupe
Old 10-26-2009, 11:11 AM   #6
diggla is an unknown quantity at this point
i ordered a extension cable on ebay for 10 bucks no issues. might be a bad cable
diggla is offline   Reply With Quote
Old 10-26-2009, 11:13 AM   #7
To "Sonicxtacy02" - Sorry, what do you mean, with this "shielded"? All of cables, that I own, have something like a ball near the end. Is this a shield:
What, about this: Click Here
If this is not a shielded "VGA" cable, please, give me a link, with the right one..
Old 10-26-2009, 12:54 PM   #8
Terminal flasher
sheilded cables are generally thicker than the pic you have posted above. The pic above shows ferrite cores which certainly help sheild the cabling from interference but the thin wire behind it kinda shows there's no metallic shielding on the cables. Buying the cable on line is kinda tricky because you really dont know what you're going to get... but the thicker the wire shown the better
03 Acura RSX Coupe
Old 10-26-2009, 02:49 PM   #9
To "Sonicxtacy02" - Thank you, very much. I will try to find a shielded "VGA" cable..
Old 10-26-2009, 06:27 PM   #10
roflcopter's Avatar
roflcopter is an unknown quantity at this point
check out monoprice. super cheap and works like a charm in my car
2007 Saab 9-3ss 2.0T
Jetway J7F5M1g5d-VHE-LF, 32gb patriot SSD, 160gb WD hdd, nLite XP sp3, EWF/Horm, RideRunner
Current Progress:
PC
HARDWARE [100%] SOFTWARE [95%] FABRICATION [100%] INSTALL [75%]
Workblog
roflcopter is offline   Reply With Quote
Carputer grounding through VGA cable ohioG35 General Hardware Discussion 7 04-30-2007 07:59 PM
PC 5 feet from amp - extend USB cable or extend RCA cable danwheeler Car Audio 3 02-10-2007 02:20 AM
Bad vga picture on long cable lez General Hardware Discussion 4 09-22-2005 04:57 PM
VGA Cable Question (Pinouts) Bugbyte LCD/Display 2 07-26-2005 09:54 AM
VGA LCD Quality with long VGA cable? vikrampant LCD/Display 4 01-11-2002 01:02 AM
