Old 04-05-2003, 07:40 PM   #1
MoNk
GPS LCd > PC
Hi, Im a REAL noob at this, so ill ask my question quickly.
What kind of plug is this, and are there adaptors I can purchase to connect it to DVI/VGA or TV-out(s-vid/composite) ?
All I know is that it supplies power and data. I've done extensive searching and can't find anything like it....I'm assuming it's quite old..?...
All help apreciated
MoNk is offline   Reply With Quote
Old 04-05-2003, 08:30 PM   #2
Registered User
Gunmaster
Model #'s or serial #'s?
Gunmaster is offline   Reply With Quote
Old 04-05-2003, 08:42 PM   #3
MoNk
I couldn't find any information frmo the model numbers on the back of the LCD.
But here you go.
FA3350590
TR-4LC2
And the rest is in japanese
Maybe someone here can read japanese, so here's a pic of the back.
Sorry it's so blurry.
Old 04-05-2003, 11:47 PM   #4
MoNk
Just found this; Doesn't look exactly the same, but is very similar.
N-DV2300 Navigation System Specifications:
_
Power Supply - 12v DC
Current consumption - less than 2.5A
Dimensions - 178x50x170mm (WxDxH)
Weight - 2.0kg
_
Reception frequency - 1575.42MHz
Reception sensitivity - -130dBm
Reception method - Parallel 8 channels
Receiving code - C/A Code
Channel system - Multichannel
Channels - 8
GPS Satellites received - 8 max.
_
Guide Map - DVD SDAL format
_
Picture Output - RGB (navigation screen) / NTSC 1.0Vp-p, 75ohms, RCA pin jack (navigation screen)
_
Analogue audio output - Monaural 1ch 1.5Vrms (1kHz, 0dB)
_
GPS Antenna
Type - Microstrip Planer
Dimensions - 42x14x50mm
Weight - 120g
_
Remote Control
Dimensions - 41x40x155mm
Weight - 65g
_
Infrared Receiver
Dimensions - 34x17x22mm
Weight - 60g
Basically that still doesn't help me much, but it could help someone help me
Old 04-06-2003, 11:35 AM   #5
mp3hombre's Avatar
mp3hombre
Damn, this is the kind of gadgets I like to get my hands on!
It is perfect for the hobbyist.
If you are handy with a soldering iron and a multimeter, PM me and I'll give you some tips on how to figure out the inputs/outputs and power connections.
mp3hombre is offline   Reply With Quote
Old 04-06-2003, 09:47 PM   #6
MoNk
I fonud out what kind of plug it was last night. Its an old Atari ST monitor plug.
Heres the ST > VGA converter http://gem.win.co.nz/mb/atarihw/stvga.html
And I'll need a DVI > VGA to go with it.
Thank god because I couldn't be worse with a sodering iron.
Thanks for all the help everyone. Hopefully there is a place in NZ that sells these ST>VGA adaptors.
I'll post back soon with pics on how it runs.
Old 04-06-2003, 09:48 PM   #7
MoNk
Old 04-07-2003, 04:33 AM   #8
I'm sorry, and you are....?
frodobaggins's Avatar
frodobaggins will become famous soon enoughfrodobaggins will become famous soon enough
That may be the same connector, but that adapter is not gonna do **** for you.
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 04-07-2003, 05:23 AM   #9
MoNk
explain, because that doesn't exactly say alot.
Old 04-07-2003, 05:28 PM   #10
tom61
It's highly unlikely that LCD has the same pinout as the ST, even if it does use the same connector.
tom61 is offline   Reply With Quote
Old 04-07-2003, 07:58 PM   #11
MoNk
I have guides that show me how to convert the Atari ST monitor cable into SCART and VGA. (however I have no soldering skills)
All the lines carry certain signals which seem easily rerouted.
Are you telling me this because you know or because you *think*? It all seems pretty pessimistic to me.
Old 04-07-2003, 08:29 PM   #12
MoNk
Have a look at this.
http://www.howell1964.freeserve.co.u...i_ST_Video.htm
Old 04-07-2003, 10:40 PM   #13
MoNk
Here's some of the inner workers. There is another connector inside which may look familiar to somebody.
Old 04-08-2003, 06:00 AM   #14
NJay's Avatar
NJay
I don't think that ST->VGA adaptor will work at all as you are going in the wrong direction.
That adaptor allows a video source that originates from a ST style output to be plugged into a standard analog VGA monitor. What you are trying to achieve is the opposite i.e take a std vga output and connect it up to a monitor that accepts an ST style monitor input
My CarPC install piccies http://www.celica-club.co.uk/cgi-bin...at=561&thumb=1
NJay is offline   Reply With Quote
Old 04-08-2003, 07:32 AM   #15
MoNk
Yeah sorry :/ I've got 2 threads asking about this and I said that in the other one but not this.
Nevertheless is would still help if I found either or.
