Old 11-04-2009, 10:14 PM   #1
BAC5point2 is an unknown quantity at this point
Alpine TME-M740BT question
Hey guys,
I want to get one of these so I can have nav in the car.
I don't care to swap out the factory HK headunit in my Outback, but I would like the bluetooth to work.
How does the bluetooth wiring work? Since my car uses an external amp stock (with line-level-inputs), how would you all suggest I wire it up?
There's a "mute" output it looks like from the screen.
Ideas?
Thanks!
BAC5point2 is offline   Reply With Quote
Old 11-06-2009, 09:14 AM   #2
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
usually, the bluetooth setup in a factory system is in the radio, so removing it will loose the bluetooth feature.
you could get a differnt nav unit with navigation and bluetooth, or you could setup a carputer with bluetooth...
soundman98 is offline   Reply With Quote
Old 11-10-2009, 09:30 AM   #3
Hmm,
I'm trying to add bluetooth though, not remove it.
The 740BT is bluetooth ready. So I can pair my phone with the screen. Trouble is, outputting the audio from my phone call. The screen has a "mute" line, or so it seems, and it also has L&R outputs.
My car, a 2009 Subaru Outback 2.5XT, has a Harmon Kardon stock stereo that uses an external amp (which is fed by line-level input).
Would it be reasonable to send the "mute" signal to the headunit (simply T it into the stock mute wire from the steering wheel control), and then plug the L/R wires into the line-inputs on the amp?
Or would that not work?
I don't intend to remove the OEM radio, simply add this screen and a NAV unit to it.
Will it work?
Ipod / usb recognition question psychotic Newbie 0 05-17-2008 06:10 AM
From Monsoon to Alpine CDA-9885 - A Bitter Ordeal Eugene08 Car Audio 2 02-24-2008 12:50 AM
Alpine digital audio setup. . maybe. Crazystick Car Audio 10 11-26-2006 10:07 AM
Hardware Review: Car2PC Alpine MBUS review MatrixPC The Review Palace 6 06-02-2006 07:39 AM
MP3 & Alpine combo question... Tripp General Hardware Discussion 3 03-31-2001 11:38 AM
