Hi Kevin
Yes you can remove the LCD + Controller + Touch panel from the case and mount it flush but you will have to fabricate everything from scratch. Many people have done this and it look very good
. I myself will eventually do this.
Here is the exact measurements for the
7" Touch Panel
I don't have one for the panel. But here is the size of the LCD panel: W 6 5/8" x H 4 1/4”. The controllers width is the same and the Height is 4 3/4".
The LCD is 250 nits which should be enough. Also if your window are tinted that helps a lot. A lot of people use TM-7002S and TM-701L with great results.
For the RCA input (composite) you will need to use TV out on the MB or a video card with TV out.
Armen
Quote:
Originally posted by khiser0001
Digitalww,
I was planning on using this monitor with your touchscreen overlay
hhhhmmmm.....
Couple of questions then. 1st I noticed the monitor has a circuit board on the back. Is it possible to remove the monitor from the case, use one of your touchscreens, and then mount it behind the factory panel? Got any ideas of how I would make the RCA inputs work?
What is a low cost solution that you might be able to offer? (Considering I want to see it in the day and want touchscreen)
I was thinking maybe I could use one of your 7 in monitors remove it from the housing and mount it flush. What do you think? What size is the actual screen assembly if it in no in the housing?
What about an overhead flip down screen? Are they sturdy enough to use as a touchscreen? Do you have any that would fit the front light assembly of an Escape?
I think I might go nuts as I thought this monitor would work for now
Thanks,
Kevin
