06-06-2003, 03:35 AM
#1
Trouble setting custom resolutions....
I am working on getting my carputer up and running. I started with the LCD display. I mimicked the setup AllenRubble has here . For now, I have my setup running as a second display off of my home PC (Radeon 8500). I know the maximum resolution the LCD can handle is 1024X512. I was able to create a custom resolution, using powerstrip, but 1024X512 looks like crap. If I use any of the windows defaults, the image looks fine, but the bottom portion of the screen is chopped off (same with 1024X512). In powerstrip, I went for the resolutions that are 16X9, as well as, some of the common ones used in the forums for the Xenarc. Although 1024X512 is 18X9, I figured I could handle a little distortion, but I can't get any custom resolution to work. Could this possible be a problem with using the LCD as a second (extended window) monitor? Even if that were the case, why can't I create any other custom resolutions. In case any question my approach, I right click the PS icon >> Display Profiles >> Configure >> (choose the second display properties for my video card) Advanced Timing Options (only real-time adjustment checked) >> Custom Resolutions >> Select the 16X9 Aspect ratio >> then choose some of the predefined options that are no greater than both 1024 and 512. Is there a fundamental problem that I am overlooking? Although I am a n00b to this sort of application (carputers), I have worked with computers since the days of DOS. With that said, has anyone had the same sort of problem? What was done to ovecome this 'obstacle?'
Thanks in advance-
06-06-2003, 03:36 PM
#2
Here the Update:
Somehow the resolutions came through that I was hoping for. With some tinkering around in powerstrip, I got the screen to fit somewhat. One of the problems I run into now is:
1. I get an on-screen message to "Change Video Mode"
2. The screen will no longer move anymore, but it needs to to fit.
Are these problems limitations of my LCD and/or Controller?
How can I remove the message? Then, how can I move the screen to fit?
Where are the powerstrip gurus when I need ya??
06-06-2003, 07:14 PM
#3
Finally, a little progress
06-07-2003, 04:25 AM
#4
I'm sorry, and you are....?
Re: Finally, a little progress
Quote:
Originally posted by SinnerG
How do I get rid of this?????
Put a piece of black tape over it
Nah j/k, I dunno man but good luck
[H]4 Life
I'm a lesbian too.
I am for hire!
06-09-2003, 08:28 PM
#5
I bought a M10000 and loaded WinXP pro. The strangest thing happened after I loaded in. I had resolutions in there that weren't windows standards, in fact, I had 1024X512 as one of the choices. Although I tried the resolution, it still came up like crap (worse than before). I returned the M10000 because it wasn't the Nemehiah core, but plan to get the the Nemehiah as soon as I can find it.
The question now is, how the hell do I get this LCD to display correctly????
06-16-2003, 05:27 AM
#6
Does anyone have any insight on this prob??
06-16-2003, 08:28 PM
#7
I think you should e-mail the controller manufacturer
[H]4 Life
I'm a lesbian too.
I am for hire!
06-16-2003, 08:30 PM
#8
or play with the h/v settings in powerstrip, maybe scan rate as well
[H]4 Life
I'm a lesbian too.
I am for hire!
06-16-2003, 09:05 PM
#9
Super Moderator
i have the same lcd as yours and I don't get that. I'm using a bigger res though
'98 Explorer Sport
80% done
06-17-2003, 11:44 PM
#10
Hijinks21-
What resolution are you using? Also, what controller board are you using? Are you using a seperate video card, or the onboard?
06-18-2003, 08:15 AM
#11
Super Moderator
i'm using some odd resolution like 854x520 or something. I forgot what it was but its something along those lines.
the board is Dicon LVDS TO VGA tft controller model # LCD1024E
I'm using a radeon 8500 for a video card.
'98 Explorer Sport
80% done
| Thread Tools |
| Display Modes |
Linear Mode
