Old 06-18-2003, 02:25 AM   #1
captain_jim1's Avatar
Lengthening LCD lines...
I have a laptop I've disassembled for use in my car, but have a small problem with the lenght of the lines connecting the screen to the laptop...
I want to know if it's possible to lengthen the data cable somehow -- can i cut and splice longer lines in without degrading signal?
How about the power line? If I splice longer lines in there will there be an issue with power? I doubt this one will be effected as much my a splice than the data signal, but you never know.
Data Signal..
Power Cable..
captain_jim1 is offline   Reply With Quote
Old 06-18-2003, 04:55 AM   #2
I'm sorry, and you are....?
frodobaggins's Avatar
you should have no problems with the power.
extending the data lines can be tricky, the quality degredation will depend on length, your connection skill, and noise introduced.
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 06-18-2003, 07:22 AM   #3
Registered User
Skraggy_uk's Avatar
he's lucky that he has proper wires to extend, instead of the usual flattened copper on a plastic sheet.
4x4 in a turbo stylee.
Skraggy_uk is offline   Reply With Quote
Old 06-18-2003, 07:54 AM   #4
Super Moderator
hijinks21's Avatar
the length of your data cables should not be over 18 inches i think I've read. The controller for it is not powerfull enough to send a strong enough signal any further then that. That said, you can give it a try and you never know .. it might just work
'98 Explorer Sport
80% done
hijinks21 is offline   Reply With Quote
Old 06-18-2003, 10:10 AM   #5
MikeHunt79's Avatar
I tried making a 1 metre long cable, and it barely worked (I used an old ide ribbon cable as an extension)... There were juddery lines, random flashes, it wasn`t very good ... It now works much better now its been chopped down to 12". I think timing and noise are your main issues here.
My Setup
MikeHunt79 is offline   Reply With Quote
Old 06-18-2003, 05:49 PM   #6
Hmm .. you mention using a old ide ribbon as an extension. How did you go about this? These wires are small so I'm not too thrilled about all this chopping up.
-Brad
83 mp320i
99 mp323i
_________
7" Lilliput w/Touch, 150 W Opus, 2.4ghz P4 533fsb, 512 DDR 333mhz, GPS, WiFi Inet, 40g Maxtor 7200rpm, Laptop DVD/CD-RW w/USB2.0 Bridge, WinXP Pro.
Old 06-18-2003, 06:08 PM   #7
MikeHunt79's Avatar
What I did was remove the IDE plugs from each end of my ide cable. I then went on to solder hirose plugs on each end of the cable... It was very very fiddly, but i managed.
My Setup
Old 06-18-2003, 06:11 PM   #8
Pardon my ignorance .. but what is a hirose plug?
-Brad
83 mp320i
99 mp323i
_________
Old 06-18-2003, 06:28 PM   #9
DodgeCummins's Avatar
Hirose is a brand name of 20-160 pin plugs that are very small...most LCDs seem to use one size. (except mine)
I also have foot long ide cables extending my LCD signals...I used bigger wire with a high voltage rating (more insulation to prevent arcing). I had to connect it to the POS plastic flat ribbon...so I have 3 bad connections...two cause a 'ghosting' effect on the lower half of the screen, the other causes the screen to go blank on occasion.
Luckily you have wires...be grateful!
current projects
DodgeCummins is offline   Reply With Quote
Old 06-18-2003, 10:09 PM   #10
Can someone point me towards a 20-pin Hirose connector? Would be sweet to use an ide cable for the extension, but have 2 hirose connectors on each end of the ide cable so i just have to "plug it in" to the existing connector... is this possible or am I dreaming?
Old 06-19-2003, 02:45 AM   #11
Raw Wave
Rob Withey's Avatar
You're dreaming. The connector in your picture looks nothing like a hi-rose connector.
The best you could hope to achieve with hirose is with 2 male and 2 female connectors. Break the existing cable and solder on a male and female in the gap so you can plug it back together. Then make a male to female extension that you can insert in the middle.
Kind of defeats the whole point of building a cable so you can just plug it in though.
Rob
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 06-19-2003, 03:52 AM   #12
Yeah that does defeat the purpose. The reason for wanting to make a 'removable extension' was to just add it to one side (not inthe middle) of the cable and then I could simply remove it if it didn't work. If I cut these lines up and can't get it to work I'm going to be in a heap of trouble...
-Capt.
-Brad
83 mp320i
99 mp323i
_________
Old 06-21-2003, 03:17 AM   #13
Help! Lengthening LCD lines...
Well, I went for it .. chopped up a IDE cable and cut the lcd signal in half .. spent the day stripping the wires and soldering .. then covering in elec. tape for protection.. here are 2 pics of the done job..
After I was done, plugged it in and booted up.. at first .. SUCCESS! I get a perfect picture of the bios boot screen .. detects ram, cpu, etc .. then it just sits there... I try to enter the bios .. says "entering bios" .. but it never goes there. Is this related to the lines I just made? HELP!
-Capt
Old 06-21-2003, 03:25 AM   #14
have you just tried to let it boot first ?
How are we supposed to know if it's related !
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 06-21-2003, 03:30 AM   #15
Yep - -that's what I tried to do the first time .. I figured I'd enter the bios to see if I would see some of the BIOS colors .. blues and yellows .. that would give me more of a sign the connections were good..
-Capt.
