Old 06-27-2003, 10:48 AM   #1
jol
jol's Avatar
jol is on a distinguished road
gamevue controller card started to smoke.
pic stolen from http://www.jrok.com/hardware/lcd/lcd_panel_fun.html
I havent tried it at all after buying it from a member here, it seemed damaged since the "came loose" component was bent. I hooked it yp anyways and it worked like it should. then everything white on the screen became yellow and i saw that the part's one leg was loose...
Tried to get some pics with my crappy webcam but no luck, and then i saw smoke coming out of the back of the screen.... it was the resistor, it had gotten so hot the solder melted! I have no idea what that component is, and what it does (it has something to do with the color atleast )
anyone who knows what it is, would you please find me a replacement at http://www.elfa.se/en/ (only top names in the table of contents is in Swedish).
the resistor i guess I can find myself.
thanks
My cars
jol is offline   Reply With Quote
Old 06-28-2003, 04:06 AM   #2
ob1
ob1's Avatar
ob1
Its a transistor of some sort....You really need to post what the markings on it are, so we can work out which transistor u need.
ob1 is offline   Reply With Quote
Old 06-28-2003, 06:32 AM   #3
jol
jol's Avatar
I lost it... but i's either:
1c
100
16v
or
1e
220
16v
could I just get two and change it if it's wrong?
My cars
Old 06-29-2003, 04:12 AM   #4
peter3's Avatar
peter3
Hello Jol,
Just opend mine and this is what i came up with.
condensator:
1F
220
16V
Mind that the blak side of it is the negative side.
resistor:
brown , black , black , gold
If i'm correct then this would be 2K ohm , but don't shoot me for it if i'm wrong. Maybe someone with more skills would know for sure.
PETER - THE NETHERLANDS - DEVENTER
sproggy 2.8,epia c3-800,20Gb 2.5", 5.6"lcd,touchscreen.
peter3 is offline   Reply With Quote
Old 06-29-2003, 09:35 AM   #5
jol
jol's Avatar
Thanks alot now i know what to get
My cars
Old 06-29-2003, 11:10 AM   #6
mp3hombre's Avatar
mp3hombre
That's a 10 ohm resistor, 5% tolerance. It's hard to tell if is a 1/2 or 1/4 watt resistor.
mp3hombre is offline   Reply With Quote
Old 06-29-2003, 11:15 AM   #7
peter3's Avatar
peter3
Quote:
mp3hombre That's a 10 ohm resistor, 5% tolerance. It's hard to tell if is a 1/2 or 1/4 watt resistor
Thanks,
Just got a hold on a meter and it says 9.9 so 10 it is.
From the size of the resistor i say its a 1/2W,
1/4W is smaller.
Old 06-29-2003, 08:09 PM   #8
eugenen's Avatar
eugenen
From the size of the resistor it looks like a 1/2 watt to me. Id put in a 1/2w it doesn't affect anything to go higher there just means it can dissipate more heat than a 1/4w.
The other is a surface mount capacitor. The dark on one side is the polarity label.
eugenen is offline   Reply With Quote
Old 10-30-2003, 02:59 AM   #9
jol
jol's Avatar
and it works again, thanks all.
The window on the crt is vnc.
I added a bunch of resistors instead of one 10, since I wasnt sure about the wattage total 10.8 ohm.
My cars
