Ok guys, tried searching my brains out, but no luck... I think the answer is "the lcd is dead".
Here's the question: I have a datalux m1023 rev f. controller and a Sharp
LQ104V1DG11 screen. In August, I hooked up everything, worked fine, had some lines going through, but I figured that was because I used an unshielded monitor cable to go to the controller. I disconnected it and put it aside until about a week or two ago when I tested it to make sure it was working...and lo and behold, it isn't.
Details:
1) All I get is a white screen. (so the inverter is working).
2) I can make the screen brighter or dimmer, so that part of the controller works.
3) I checked the pinouts from the cable going from the video card to the controller (about 4 times), and it's all correct (and it worked before, so that shouldn't be the problem).
4) I checked the continuity on every pin of this cable (three times...ugh).
5) Checked continuity on half of the 31-pin hirose cable (those are such a pain....I don't think this cable is the problem as I didn't solder it..had it made somewhere else, pretty sturdy..)
6) Checked to make sure the two 5 volt pins were indeed supplying 5 v...which they are...
7) Plugged in a controller for the LQ10D421 which has the same pinouts as the lq10v1dg11 (man that's a pain to type) that has its own hirose cable...still no picture.
GAH! So I figure it's either the hirose connection itself on the lcd (which looks fine to my eyes) or some other electrical problem with the screen that must've occured while in storage..
So...I'm going crazy over this, any ideas?
