Old 07-08-2003, 07:22 PM   #1
skippy_geek
Double DIN Flip mount
Ok, I've been reading here for a while now and after much discernment, what I've decided I want to do set everything up so that the 7" screen covers the double din spot on the dash of my Honda civic. Here's the kicker, I want to mount a dvd-rom drive and a memory card reader behind the screen, so whenever I need to access/inset media, I just flip the screen down and flip it back up, like the glove box. Any ideas how to go about this in terms of the harness??
Skippy
skippy_geek is offline   Reply With Quote
Old 07-08-2003, 08:56 PM   #2
Maxis24's Avatar
Maxis24
Well, I am no genius, nor am I very good at giving descriptions of mechanical systems, but I'll try my best.
You have a double din sized opening. Be carefull, because some of the double din openings (like the one on my Focus) isn't large enough for the screen to fit without using a dremel to either the screen case, or the radio opening.
What you are going to want is a pin & slot type system. The camera rests in a housing that is mounted to a bracket that has two pins sticking out the sides. These pins stick into a divot/hole made in the plastic (of the car) on the left & right sides of the screen. The screen is allowed to swing on the pins freely, so I would recommend putting a lip on the front of plastic to allow the screen to move down a little bit. To put it up, just give it a push up and back. That should work as long as your Civic has as much room behind the radio opening as a friend of mine's '93 Civic.
Hope this atleast helped brighten your own ideas.
Maxis24 is offline   Reply With Quote
Old 07-09-2003, 12:04 AM   #3
Raw Wave
Defiler's Avatar
Defiler is on a distinguished road
I know Digitalww had a double din DVD/CD reciever w/ a screen on the front of it at one time on his website...maybe you could ask him about it.
Defiler is offline   Reply With Quote
Old 01-06-2006, 02:23 AM   #4
agmsd's Avatar
agmsd is on a distinguished road
Please point me out if I'm wrong but the only available dual din Housing is for Subaru only but you can get to fit with some modification in many cars and that what I'm planning on till now...
agmsd is offline   Reply With Quote
Old 01-06-2006, 02:42 AM   #5
My Village Called
0l33l's Avatar
0l33l is on a distinguished road
0l33l is offline   Reply With Quote
