Old 08-19-2003, 03:01 AM   #106
lazarus's Avatar
yeah it matters. only one side is touch sensitive, and there is a top and bottom to it. on mine if you are looking straight at the panel with the header cable to the left hand side, and the sticker on the cable facing you then it was the right way round. just make sure you get the cable plugged in to the controller the right way round or its like drawing in mirror image.
Personaly i just hooked it up on my main rig with out it been placed over a monitor, and experimented until i could move the mouse pointer normaly round the screen, almost like i was working on a drawing tablet.
lazarus is offline   Reply With Quote
Old 08-19-2003, 03:26 AM   #107
Registered User
Skraggy_uk's Avatar
Ah, excellent. Thats what I wanted to know. I take it you mean the big white cable/foil strip with the big whit sticker. I want that to the front, with the writing the correct way up then.
4x4 in a turbo stylee.
Skraggy_uk is offline   Reply With Quote
Old 08-19-2003, 04:14 AM   #108
I imagine the boot time on 2k is a draw back.......
Blop is offline   Reply With Quote
Old 08-19-2003, 04:20 AM   #109
Registered User
Skraggy_uk's Avatar
Not too bad. About 20 seconds if you use hibernate.
About a minute if you use full shutdown.
Just do a normal shutdown/reboot about once a week to keep the hiberfil cleaned out.
Old 08-19-2003, 05:33 AM   #110
Heh skraggy, after a lot of searching i have a screen.....
http://cgi.ebay.co.uk/ws/eBayISAPI.d...gory=3698&rd=1
http://www.lcdspecifications.com/nec...448bc33_31.pdf
So all i need now is a controller card which i have no doubt will cost an arm and a leg......
Old 08-19-2003, 05:34 AM   #111
20 secs to hibernate is an age compared to 98lite setup it shutsdown in like 2 seconds if that its really good.
Old 08-19-2003, 05:43 AM   #112
Registered User
Skraggy_uk's Avatar
Now you have the panel, mail earth LCD and see what controllers they have that will suit it. Will be prices though.
Old 08-19-2003, 05:46 AM   #113
Registered User
Skraggy_uk's Avatar
20 secs is not too bad. Start the car, hit the Headunit switch, listen to the inverter beep to say you have power, put on your seatbelt, and before you know it, the music starts off where you left it.
The Saab is an old oil cooled only turbo, so you need to let it idle for a minute or so before you switch off. Just start the shutdown, when it goes off, switch off the HU, then switch off the engine. Works for me.
Old 08-19-2003, 05:56 AM   #114
That seems to be perfect for your enviroment then...to be honest i am no where near putting it in the car so i am just thinking 'faster is better' but i suppose when i actually install it and experience it, i will be able to make judgement on the boot times i need etc....
Old 08-19-2003, 05:57 AM   #115
What did u think of the screen and touchscreen? Was it fair for the price.....?
Old 08-19-2003, 05:59 AM   #116
Registered User
Skraggy_uk's Avatar
Seems fine. Goods details, plenty of specs and stuff. Price not bad.
Old 08-19-2003, 06:33 AM   #117
Which lcd controller?
Ok, which lcd controller should i get :
analog to digital or analog to analog
And with that decided are all controllers compatiable with all lcd panels.....
Are there special features i should be looking out for, i take it OSD is part of the controller....
Old 08-19-2003, 06:41 AM   #118
Registered User
Skraggy_uk's Avatar
Best is contact EarthLCD tell them what panel you have, and what features you motherboard or video card has.
Probably want an anologue RGB connection to a standard 15pin VGA card. They will tell you which controller and cable set you need for the that screen.
You might get lucky and find Trident or hero Electronics in the UK have a kit for that screen.
Can't remeber the addesses, but something like heroelec.com, and tridantdisplays.co.uk
Old 08-19-2003, 07:52 AM   #119
trident werent to helpfull..... they said they would have to reconfigure a standard card or something....
http://www.earthlcd.com/CNTEVAD2.htm
But that would do the trick wouldnt it?
Old 08-19-2003, 07:53 AM   #120
Registered User
Skraggy_uk's Avatar
Will do if it is compatable with your screen and they have cabling for it. Contact them.
Doesn't cost to ask questions.
