Old 08-11-2003, 05:15 AM   #1
Registered User
Skraggy_uk's Avatar
I Need help installing a TSK?
I've stripped the Taxan monitor down.
Found it has this panel.
Active area of the panel is listed as 211.2x158.4mm
Was wanting order the 10.4" TSK from Armin@DigitalWW.
The active area according to the schematic is 212x159.4mm
That makes the active aprt of the TSK roughly 1mm bigger than the active area of the panel.
Before I order the kit, I want to know if it will cause any probs having the active area of the kit bigger than that of the panel.
The monitor when new did have the option of a touchscreen, and the front of the panel is recessed slightly (arround the metal work), almost flush with the TFT itself.
Would it just be a matter of attaching the TSK to the panel with some double sided tape along it's border outside of it's active area, and making sure that the panel was spaced away from the new console surround so that the touch isn't operated by pressure from the surround (like the retro fitted touch kits did on the *enarc screens)?
I'm hoping it is that simple as I want touch once I get it all together, and then I can lose the trackball once and for all (still connected but hidden away for emergencies, under the rear seat).
TIA all.
4x4 in a turbo stylee.
Skraggy_uk is offline   Reply With Quote
Old 08-11-2003, 06:14 AM   #2
I'm sorry, and you are....?
frodobaggins's Avatar
As long as nothing is touching on the active area and it is calibrated properly I can forsee no problems
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 08-11-2003, 06:44 AM   #3
Registered User
Skraggy_uk's Avatar
Nice one. Cheers. Guess Armin is going to be making a little cash today then.
Old 08-12-2003, 10:22 PM   #4
digitalww's Avatar
Thank you for your order.
Check your PM for the tracking #. I will ship the kit tomorrow so it will not track until tomorrow.
Thanks,
Armen
http://www.digitalww.com
digitalww is offline   Reply With Quote
Old 08-13-2003, 03:23 PM   #5
Registered User
Skraggy_uk's Avatar
Hey Armin. Thanks for everything. Eventually get the notification mail for the PM. With notificatins being down, I've missed a lot of updates on threads.
