08-18-2003, 02:30 PM
#1
how do you power your dscustoms or wwdigital screen?
Hi Folks - I was wondering how you power your wwdigital or dscustoms 7" touchscreen? I tried searching - but apart from the opus thread i found nothing obvious to my very untrained eye.
Thanks in advance,
P.
08-18-2003, 02:38 PM
#2
Any good 12V source will work. If u have an inverter, you can use the supplied AC/DC adapter. Or, you could plug it into a free 12V DC car socket. Or, you could use the yellow/black 12V leads from the PSU (Preferred).
08-18-2003, 02:41 PM
#3
I power my lcd through the power wire of my head unit since it is so close. You can also wire the lcd straight to the battery.
EPIA 800, DWW-7VGA LCD w/Touchscreen, 256mb ram, dvd rom, ati radeon 7000 video card, 80 gb 3.5" hard drive.
08-18-2003, 10:03 PM
#4
what about fusing the power wire? necessary?
2005 Mustang GT:
12w7...arc audio kar1000.2t...jl 300/4 pushng focal 165k2p...pioneer premier deh-880prs...tm-701l...audiocontrol eqs
want: my stereo actually IN the car
08-18-2003, 10:08 PM
#5
always a good idea to fuse anything you add to the car
08-18-2003, 11:38 PM
#6
i've got mine off the opus
08-19-2003, 12:34 AM
#7
Registered User
freestyler, how did you figure out which wire was ground and which was power? Im assuming it can be done with a multimeter, but i've forgeten all i learned in EE class.
08-19-2003, 12:49 AM
#8
yellow = 12v
red = 5v
black = ground
08-19-2003, 01:03 AM
#9
I thought there was issues that the unregulated voltage from the car power causes flickers..
Is this true?
2k3 Max SE 6spd
Temp setup:
7" indash screen/Xbox running XBMC
Carputer coming soon
My 2003 Maxima
08-19-2003, 11:05 AM
#10
Yeah, its always a good idea to use a fuse. The wiring going to the head unit is fused already but if you wire it straight to the battery its a good idea to use a fuse.
08-19-2003, 11:16 AM
#11
MiniRX7;
The flickering depends on the car and its electrical system. It worked fine in my Qx4. I did so for about 4-5 weeks. But if for some reason their was a power spike, you may fry the screen. You should try to use a regulated power source to protect your investment. I now power the screen from my Opus.
08-19-2003, 11:57 AM
#12
I just used my Opus 150Watt.. Cut the plug off the CPU Power (Didn't need it) and then made a wire from that to the screen - 12v regulated, and everything turns off when the computer does!
08-19-2003, 06:05 PM
#13
Registered User
freestyler, i meant how do you find the + and ground wires coming from the screen, not which wires to hook them up to, i do remember some stuff  .
08-19-2003, 09:08 PM
#14
haha...sry
stupid moment, brain = fried with summer finals
the ribbed wire is the posi, i just probed it with my meter
| Thread Tools |
| Display Modes |
Linear Mode
