Old 09-04-2003, 11:28 PM   #1
Seraph's Avatar
Seraph is on a distinguished road
I found a SHARP LCD
I was digging through my pile of junks and I found a Sharp LCD that I used ages ago. I recall burning out the controller board though but LCD is fine. It says LQ6BN01 on the LCD. How do I go about finding the right controller?
L
Seraph is offline   Reply With Quote
Old 09-04-2003, 11:38 PM   #2
chut's Avatar
chut
Try www.earthlcd.com I heard their very expensive.
Peter
chut is offline   Reply With Quote
Old 09-05-2003, 12:05 AM   #3
Seraph's Avatar
In that case, I might as well toss out the LCD.
Old 09-05-2003, 02:58 AM   #4
BurgerBoy's Avatar
BurgerBoy
try http://www.lcdcontrollerkits.netfirms.com/
I like stuff :D
BurgerBoy is offline   Reply With Quote
Old 09-05-2003, 09:06 AM   #5
Registered User
mp3z24's Avatar
mp3z24
L
well.. first off, what kind of connection is on the back? is it a 31 pin connection (hirose)? or is it a ~20 pin flat ribbon connection?
if it is the 31 pin connection, then you my friend will need a controller card. that is where it gets expensive.
if it is the ~20 pin ribbon cable connection, then you will not need a controller card. in that case the screen will be a composite screen, and you will be able to feed it video from an rca cable.
i suspect it is a composite screen, as i have 2 sharp lq6nc02 screens, and they are composite. if you need any help, i can see what i can do for assisting in hooking it up.
~Mike
edit.... 1000th post.... woo hoo... where are my gifts!?!?
Single Member of the "1000 Post and No MP3 Car" Club
PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
2000 Cavalier Z24 [###-------] Only 30% Done ... Still
mp3z24 is offline   Reply With Quote
Old 09-05-2003, 11:12 AM   #6
Seraph's Avatar
It has a 20 pin ribbon. What do I do to get it to work.
L
Old 09-05-2003, 05:05 PM   #7
Registered User
mp3z24's Avatar
mp3z24
L
alright... making the BIG assumption that the pinouts are the same...
check this page. Pinouts
there you should see the requirements for hooking up a lq6nc02.
WARNING I DONT KNOW IF THESE ARE THE SAME PINOUTS. typically sharp has the same pinouts across models, but i dont want to be blamed if anything bites the dust.
all you really need to hook up is the +5V, -8V, ground, and input. all the adjustments are by potentiometer, and are not really needed to run the screen.
the -8V might be the hard one to get... i might have a solution at home. the board that i got for mine came with a chip for this... i'll see if i can figure out what it is.
also, this screen may have the capability to run off component input. but not at full component resolution (obviously)
Good luck
~Mike
Old 09-06-2003, 10:42 AM   #8
Seraph's Avatar
Thanks mike. You are in Chicago area too. How would you put RGB from the monitor out to this thing? I assume the LCD may not be as sharp as VGA screen but would be better than composite in right?
L
