Old 09-05-2003, 07:42 AM   #1
[TWSTED]'s Avatar
[TWSTED] is on a distinguished road
Casio LCD
Hi,
I have Recently Aquired a Casio LCD Screen off a Casio In-Car GPS System. THe Main Unit is dead but the LCD still works. The LCD Contains its controller board. Its just that I cannot find any information on the LCD or the Actual unit. I need to know which Connections to use to connect this unit to a Matrox Millenium G400 Video card.
There are Several Model numbers on the Units.
The one inside the Unit is 635-M
[TWSTED] is offline   Reply With Quote
Old 09-05-2003, 10:32 PM   #2
tom61
A picture would help greatly.
Also, the board attached to it probably isn't a controller board, but an inverter for the backlight instead (made this mistake a few times myself). I can't tell you for sure since I haven't encountered this screen before, and have no picture to reference.
Try doing a Google search for every number you can find on the boards for info, maybe you'll get lucky and it's one of the odd ball devices that use composite video.
tom61 is offline   Reply With Quote
Old 09-05-2003, 11:57 PM   #3
[TWSTED]'s Avatar
ive searched. ill post a pic soon
Old 09-05-2003, 11:58 PM   #4
[TWSTED]'s Avatar
The Board is the COntroller because the Signal goin into it is seperated. into Red green and Bluw
Old 09-06-2003, 04:56 PM   #5
tom61
Then question is what signal does the controller take. If you're lucky it might be something a normal card can output, if you're not lucky it may be something like digital RGB.
Old 09-10-2003, 07:52 PM   #6
[TWSTED]'s Avatar
When I jacked into the Red, Green, and Blue signals on a TV Using a Composite Input It appeared on the Television but it was in black and white and was missing Sync.
Old 09-10-2003, 08:36 PM   #7
I'm sorry, and you are....?
frodobaggins's Avatar
frodobaggins will become famous soon enoughfrodobaggins will become famous soon enough
You might want to try the same thing that is being done with the playstation screens, there are a couple threads on this
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 09-10-2003, 09:14 PM   #8
[TWSTED]'s Avatar
I Disassembled the LCD and I saw on the Opposite side of the Board Pin Abbreviations, There was one saying CSync. Anyone have an Idea what signal is needed there?
Old 09-10-2003, 11:29 PM   #9
[TWSTED]'s Avatar
Hmmmm. I Might do what was done in the PS1 LCD Mod Guide.
But im not sure if my G400 supports Sync on Green.
Old 09-11-2003, 05:27 PM   #10
tom61
Don't worry about Sync on Green, as your screen takes Composite Sync (what CSync means). Just follow the guides instructions for software, and connect H-Sync and V-Sync from your hacked VGA cable to CSync, and Red, green, and blue to the proper places (probably labled R, G, and B on the board).
I'm glad you got lucky with this screen, far too many don't have controllers.
Old 09-11-2003, 08:48 PM   #11
[TWSTED]'s Avatar
Tom. I tried using the two cables straight into the Csync but the picture keeps rolling and I cannot find the Right Timing. BTW Does a Matrox G400 Support CSync? If so Would I need to use one cable or both
Old 09-12-2003, 05:37 AM   #12
[TWSTED]'s Avatar
Here are Pictures for the people who would like to see them before They can give me ideas.
Old 09-12-2003, 05:37 AM   #13
[TWSTED]'s Avatar
More
Old 09-12-2003, 05:37 PM   #14
tom61
If it come up in Power Strip as an option, then yes. If I remember right, the H-Sync wire becomes C-Sync if this is turned on.
What is that almost empty board in the first pictures?
Old 09-12-2003, 06:06 PM   #15
[TWSTED]'s Avatar
thats my experimenta; csynnc convertpr
