A couple of interesting things-
Transmitting VIDEO is compleetly different than transmitting VGA.
CompUSA sell a device by Grandtech USA that is basically the same as the Aussi link, expect not in kit form, its a finished product in a box with all the little connectors and cables.
http://www.compusa.com/products/prod...147&pfp=SEARCH
Oh , these guys also sell a similar set up -
http://www.polarisusa.com check the wireless video section - its pricey, but looks a bit more ruged / commercial - option antennas Etc.
I dono anyone that makes a truely wireless VGA to VGA setup (would love to find one though)
The cheaper solution is to scan convert VGA to video , then transmit the composit signal.
First check out
http://www.linksys.com/products/grou...rid=33&scid=38
Look at the wireless presentation gateway and player (I cant tell the difference between the two)
A number of different companies make a prodcut to convert a VGA signal for transmition over cat 5 UPT. most of these devices DO NOT convert the signal to ethernet, only change the vga cable into UTP (and back) the more expensive devices actually convert the signal into IP/Ethernet data.
Another route -
Many companies make a device called a KVM switch. These switches are typically used to connect multiple computers to one Keyboard, Vga monitor, and Mouse (hence the name)
Many of the KVM makers now have A product that converts the signal to packets (tcp/ip / ethernet) The problem now is, I have yet to find one that will convert the IP data back into an analogue VGA / keyboard / Mouse signal.
They all make a software application (like pcanywhere or Win VNC) that runs on a client PC to connect to the box.
If you dont mind the client pc & the software app displaying in your VGA window- it would work
Video transmitters are comon these days - You can split the vga signal to R G B, and use a transmiter for each - then you just have the sync portion of the signal to worrie about - I dont know the specs on the sync.
For KVM info check out
http://www.avocent.com or
http://www.raritan.com
