Old 09-10-2003, 04:06 PM   #1
Sunglassesron is on a distinguished road
Tell me where I'm going wrong PLEASE,
Ok I recieved my screen this morning, I think its the older Xenarc TS, 7" widescreen, I have connected it to my pc and it flickers like hell, the screen is there but scrolling is all wrong and a constant flicker....
That was on a gf4 TI 4200 and tried 640x480 60hz, 800x600, the lot.
Then I tried it on my carputer, which is in the house, and the same happens, screen fades etc, goes white,
Then tried it on my laptop with a mobile ATI chip and got the same, using all resolutions, EXCEPT when I set the screen as a flat panel in the ATI settings it works perfect at 640x480,
So what am I doing wrong with the normal pc's
I also downloaded powerstrip and it just turned my pc black when I clicked on it lol,
Cheers if you can help
Ron
Sunglassesron is offline   Reply With Quote
Old 09-10-2003, 04:34 PM   #2
Super Moderator
hijinks21's Avatar
hijinks21 is on a distinguished road
check the refresh rate.. try to set it to 60?
'98 Explorer Sport
80% done
hijinks21 is offline   Reply With Quote
Old 09-10-2003, 04:38 PM   #3
I have mate, It keeps saying unkown mode now, this is on a PAL system but I brought the screen from the US.
Does this matter, it does say PAL on the OSD
I have tried every setting on the display and none work.. what can it be?
Cheers
Old 09-10-2003, 05:02 PM   #4
Super Moderator
hijinks21's Avatar
are you sending an ntsc signal from your video card? playing pal on a ntsc only lcd won't work.. but a lot of them will show both ntsc and pal
'98 Explorer Sport
80% done
Old 09-10-2003, 05:05 PM   #5
chut's Avatar
chut
uh yea, what he said. It does matter.
chut is offline   Reply With Quote
Old 09-10-2003, 05:17 PM   #6
tejesh83
Sound like an out-or-range problem.
Try to find the specs on the older xenarc for supported resolutions @ refresh rate.
It may only support the native resolution. Current spec says: 800 (H) x 480 (V). But, you'll have to find the data sheet for your specific screen if that doesn't work.
tejesh83 is offline   Reply With Quote
Old 09-10-2003, 05:21 PM   #7
Well I live in the UK so I should be pushing out PAL, I dont know how to change the V card to use NTSC, I have tried a legacy ATI Xpert card, PCI under win98 and still does not work the screen just fades to white, I do catch a glimpse of the windows screen,
When you say PAL/NTSC this unit is auto switching, so it should sense if its ntsc or pal? It says pal on the OSD, this is baffleing me, I will have to email quincy who I brought it from as he said it was working fine, I also notice this weird stuff whe it fades, it looks like a game, and says ENTRANCE up the top, is this some kind of burn in or simthing?
ANyone?
btw its a Xenarc 7" 700TSV if thats any help, I'm sure loads of you have them
Old 09-10-2003, 05:43 PM   #8
OK guys sorted, I am on it now basicly you have to let windows determine its own timing settings in the GF 4 control panel, now I am running in 640x480, need to make it a little bigger though
Thanks for the help,
