Old 10-01-2003, 12:56 AM   #1
Mount lcd in dash or console?
should i put a dscustoms screen where the radio opening is (i think its only 1.75 din though, so fiberglass and bondo will have to help make the opening bigger) or should i put it in a console like the *MOCK* one is below? i know it would probably look a little cleaner in the radio opening, but the console really interests me because i can store my computer in there, relocate my radio to it. it kind of reminds me of a hummer console just because its pretty high and the screen totally faces the driver. thanks -Ryan
ryanerb is offline   Reply With Quote
Old 10-01-2003, 02:42 AM   #2
carabuser's Avatar
second setup(mock) would be a pimp install, since nobody else has anything like that, but I think it takes up too much space. so if space isnt an issue for you, all i can say - go for it!
2000 Maxima CarPC
Current Status: Rebuilding
Specs
- 1.5Ghz Toshiba Laptop
- Indash Motorized 7" VGA TS
- DeLorme GPS
- Power Inverter
- Pioneer HU
carabuser is offline   Reply With Quote
Old 10-01-2003, 03:23 AM   #3
In Dash
You should put it in the dash. You do not want to give up all that extra space.
It looks like 1.75 * DIN, not 1.5 * DIN. I think you have enough room to squeeze it in. Just go to a junk yard and get a second dash plate to work on.
--Tom
ciagon is offline   Reply With Quote
Old 10-01-2003, 08:52 AM   #4
build your console below your climate control..... that a way you have your cake and eat it too
ALIBABA - I30 99
Nemiah M10000, C134
DVD, 40Gig, 256MB DDR
GPS, OBD 2, Reverse Cam
Mute on stereo w I300 car kit
Liliput 7in w usb touch screen
Direct connect with BOSE-CD changer
skassama is offline   Reply With Quote
Old 10-01-2003, 08:56 AM   #5
Confusion Master
Enforcer's Avatar
I would change the colour scheme on the console if you go for it.
As skassama says, build a smaller console under the CC, the mock you've done is way toooo big.
also getting a dup dash plate is a good idea, that's what I want to do before I start hacking away my dash.
Enforcer is offline   Reply With Quote
Old 10-01-2003, 10:06 AM   #6
ya, i need to go get another front bezel down at the junk yard although the one i already have is kina crappy. here is my idea for the climate controls. i wanted to control them via stepper motors/servos. i would have a digital control on my computer, and the motor or servo would turn the knob to the position that i set it on on the computer. if im going to put a computer in my car, i want to integrate it into my car as much as possible. also, i kina like the console a little higher, cause my arm rest's right on it, and the screen is up closer to my eyes. space isn't really an issue for me. im still definitely thinking about it, just want the board's opinion. thanks -Ryan
Old 10-01-2003, 10:17 AM   #7
jol
jol's Avatar
You gonna smuggle aliens in that thing? I'd use the hu's space and put the hu under the dash
My cars
jol is offline   Reply With Quote
Old 10-01-2003, 11:26 AM   #8
acornstu's Avatar
smuggle aliens!!! ha ha ha!!! that's great, with that much room i'd go ahead and find a bigscreen tv for it!!!
acornstu is offline   Reply With Quote
Old 10-01-2003, 01:01 PM   #9
BBrinks's Avatar
I've read on this forum for a long time now, and this is my first post.
Here's an idea for you:
http://www.termpro.com/cgi-bin/ubb/u...&f=32&t=000571
Similar vehicle, you could just modify it to house an LCD screen.
BBrinks is offline   Reply With Quote
Old 10-01-2003, 01:16 PM   #10
I have done both and like the monitor in the dash a bit better. Althought after looking at your mockup I am getting ideas for version 3
My 1st setup I installed a Expy. Console in my F150 and placed the computer and screen in the new center console. I was never able to get the angles the way I wanted.
So I moved my AC controls to the center console and mounted the screen in the dash. I still need to fininsh the fiberglass on the dash bezel, but it is there and working.
Keep us up to date. I am always looking for new ideas for my Truck .
Let me know if you have any questions.
Jeremy
2004 F350 Ext. Cab
System not reinstalled in it yet
Typhoon747 is offline   Reply With Quote
Old 10-01-2003, 01:21 PM   #11
jol
jol's Avatar
holy **** I gotta learn that some day
My cars
Old 10-01-2003, 04:51 PM   #12
jeremy, did you have to extend the vacuum lines on your a/c controls when you moved them down?
Old 10-01-2003, 08:01 PM   #13
I am not sure, I had the shop that installed my alarm move them down into the hole in the console I cut for the 1st LCD. I thought they would have too extend them (That is why I asked them to do it), but it did not look like they had too.
2004 F350 Ext. Cab
Old 10-04-2003, 10:23 AM   #14
wi77iam's Avatar
Be careful. I was just told by Dave at dscustoms that attaching your screen to your dash will void your warranty. I thought the only thing that would do that is opening the case. It seems that these things are so fragile that probably just looking at it crosseyed will void your warranty.
Good luck.
wi77iam is offline   Reply With Quote
Old 10-04-2003, 12:57 PM   #15
dave... can i get some input on this? well i guess almost everyone on here has voided their warranty...at least the people with the sweet installs. sometimes you gotta do what ya gotta do. i lifted my truck, im sure that voided the warranty. -Ryan
