Old 10-07-2003, 07:00 AM   #1
gsand's Avatar
Question VGA to COMPOSITE
I remember seeing a site on which there was a circuit for converting VGA to Composite. I cant remember the URL, or what the site was called so can anyone help me out?
gsand is offline   Reply With Quote
Advertisement Sponsored links
Old 10-07-2003, 09:26 AM   #2
Confusion Master
Enforcer's Avatar
don't bother, get either a VGA monitor or if you really must have pal, get a card with TV out.
Enforcer is offline   Reply With Quote
Old 10-07-2003, 07:21 PM   #3
gsand's Avatar
mm.. Thanks. Thing is, i already have a PS One LCD ready to go, and i cant be bothered to buy a PCI tv out card. (no agp slot on my board)
Old 10-08-2003, 02:58 AM   #4
Raw Wave
Rob Withey's Avatar
Go to the search page. Enter the following into the search panel:
psone AND lcd
Hit the "Search Now" button. A lot of hits will come up showing you how to connect a VGA port to a psone lcd.
It doesn't matter that you don't have an AGP port on your board if you're trying to plug in a PCI tv out card - they need a PCI slot...!
Rob
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 10-08-2003, 03:08 AM   #5
gsand's Avatar
psone AND lcd
Rob
Thanks for the help, i already knew both....
4st Insanity
:google:
Old 10-08-2003, 03:24 AM   #6
http://www.tigerdirect.com/applicati...4&sku=O38-1010
is this what you are looking for? there are many others out there like this.
s_hartmann_83 is offline   Reply With Quote
Old 10-08-2003, 03:53 AM   #7
Freeman's Avatar
hmm.. has anyone used one of those things (the above post) ???
It aint no family car.
SEE MK2 At : -
http://www.mp3car.com/vbulletin/showthread.php?t=22810
Freeman is offline   Reply With Quote
Old 10-08-2003, 05:13 AM   #8
gsand's Avatar
Those things a great, and would probably be an ideal solution, but i reckon the price is too steep. If i was going to buy anything that gets me an actual TV-Out port, i would buy an PCI Video Card with TV-Out. That way, i score a half decent video card that would greatly increase the systems current score of 1.5 in 3DMark 2000 . Such an example of this would be a PCI model of the GeForce 4 MX440 . Also, the low profile of that particular card would help me make the case smaller.
Or i could just Wire my PS screen straight to VGA, but i cant be bothered scewing around with smal wires and compact soldering.
IT isnt of anysort of referance but my mobo is the Jetway 920BF
4st Insanity
:google:
Old 10-08-2003, 05:21 AM   #9
Registered User
jakeep's Avatar
I have been using one of those adapter type things for about 1 1/2 years now. and it does the job quite nicely.
HOWever, if you are using a tft (NON VGA) screen then you dont really notice much degredation on the small text, because it looks terrible anyway.... livable but nothing like a vga screen. the only *** ache with the one I had was that it just looked messy with extra wires hanging around.
Its a cheap alternative to a VGA screen >>>> but not as cheap as just getting yourself a 32mb Pci Graphics card off Ebay for £20 (but then you have to get a dummy VGA adapter for it to work independantly)
IMHO by the time you have fannied around bought an adapter, sorted it out etc you will have wished you had Bought a mini ITX with built in phono out, and a quick 800mhz C3 cpu...... wish i had just done that... is a lot simpler! and cheaper... and smaller! in the long run!
Audio:Pioneer KEH P6900R, CD multi Changer, CD-RB20 Aux input adapter.
System:AMD550, 192 Ram, 13Gb HDD, Via Micro ATX, o/b Sound, 32Mb G/c, T/screen In-Dash 7" LCD VGA, IrMan, 120w inverter.
O/s:Windows 98lite
Software:MediaEngine 1.7.7
jakeep is offline   Reply With Quote
Old 10-08-2003, 05:22 AM   #10
Registered User
jakeep's Avatar
OOoooo and I almost forgot.... this link might help you:
VGA to tv/Phono diagrams
O/s:Windows 98lite
Old 10-08-2003, 05:38 AM   #11
gsand's Avatar
mm, thanks jakeep. I already have the cpu and ram and am buying the mobo tomorow for $39 australian, compared to 300 for a new Nehemiah. My PS One screen is very readable running off a composite signal. I have it going at 640x480 with 150% font size. And besides, it will mainly be used for watching dvd and playing mp3's. The screen looks great watching DVD, its only when you look closley that you notice the pixels and the lower quality. I found a Radeon 9000 PCI with tv out for $52 US, so that might be worth a look. In the end, i'll probably just wire up my LCD to run directly of VGA.
4st Insanity
:google:
Old 10-12-2003, 05:15 PM   #12
there is a chip who can help you. it is a AD722 rgb to ntsc converter ...
coromonadalix is offline   Reply With Quote
