Old 10-07-2003, 08:29 AM   #1
guvi's Avatar
Question Temperature Problems
Hey.
I´m thinking about installing a raw TFT-Display.
But the most Specs say, that the working temp.range is between 0°-50°...
What could happen in winter, when it´s very cold?
tia,
guvi
The Spanish Style...
SEAT LEON! My CARPC-Install or the thread up here
guvi is offline   Reply With Quote
Advertisement Sponsored links
Old 10-07-2003, 09:27 AM   #2
Confusion Master
Enforcer's Avatar
do you get in the car when it's less than 0 degrees celsius?
coz I sure wouldn't.
Enforcer is offline   Reply With Quote
Old 10-07-2003, 12:01 PM   #3
guvi's Avatar
when i get up in the morning an go to work i have to use the cold car. sure, that the temperature will rise during driving ... but what will happen at the beginning? will the screen not working?
my car is standing the whole night outside
Old 10-07-2003, 12:17 PM   #4
fluffy2097's Avatar
Try a search. This has been covered MANY times.
A digital mind lost in an analog world.
Learn to ask smart questions!
http://www.catb.org/~esr/faqs/smart-questions.html
My car PC: The Lost Cause!
fluffy2097 is offline   Reply With Quote
Old 10-07-2003, 12:52 PM   #5
Confusion Master
Enforcer's Avatar
remote start the engine, with the heaters on full.
Old 10-07-2003, 01:58 PM   #6
jol
jol's Avatar
between 35 and 40 at the lowest here.
My cars
jol is offline   Reply With Quote
Old 10-08-2003, 04:28 AM   #7
Confusion Master
Enforcer's Avatar
so you are well within the 0-50c working range then
or do you mean -35 and -40.
Old 12-03-2003, 10:07 AM   #8
Registered User
ose-ml320's Avatar
My Lilliput's touchscreen hasn't worked properly the last 2 mornings with temps in the 40-50F range.
It seems the top plastic layer of the screen, which I assume is the Touchscreen, bubbles up and away from the LCD, which seems odd. I would think the plastic would contract in the cold, so I figure there is a metal frame holding the plastic film tight, and the metal is shrinking a bit causing the tension on the plastic to loosen. Problem goes away when things warm up, but it takes 15-20 minutes.
Anyone else have this problem? possible solution?
TIA
Scott
MCS-PC
Epia M-10000
XP Pro; 512MB; 60GB (2.5")
Panasonic Slot SlimDVD/CD-RW
7" Lilliput (Touchscreen)
Casetronic C137 w/ 90W PSU (Temp)
19V Laptop Adapter (Temp)
ose-ml320 is offline   Reply With Quote
Old 12-03-2003, 07:00 PM   #9
Here in NY its been 15-20F and the screen still works fine
ibewslave is offline   Reply With Quote
Old 12-05-2003, 11:12 PM   #10
Self proclaimed spoon feeder
TruckinMP3's Avatar
Uhm.... 0 C is = to 32F defined as the freezing point of H2O.
The display may be sluggish untill it warms up. Any other issue would not be related to Temp.
TruckinMP3
Self Proclaimed Spoon feeder!
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 12-16-2003, 05:45 PM   #11
Here in minnesota...my stereo head unit will just about freeze... i gets to -20 F. (w/o windchill sometimes)
codyj86 is offline   Reply With Quote
Old 12-16-2003, 06:28 PM   #12
TruckinMP3's Avatar
Windchill is an effect on people not equipment. It is the feels like temp that we would be exposed to if the wind was not present.
TruckinMP3
Read the FAQ!
Old 12-29-2003, 01:39 PM   #13
Goose's Avatar
you guys are talking a lot about your screens working fine in cold.
But try answer this.
you are stoping the car. it is -20C to -30C outside.
The car is standing there 3 days without using.?The LCD is mounted in the dash.
what witll happend with this LCD?
Will it be destreoyed becouse of cold (so I habe to buy ned one)
or will the LCd be fine but I haveto worm it up before I turn it on and the screen will after some time and worming be good as new?
Goose is offline   Reply With Quote
Old 12-30-2003, 01:06 AM   #14
jol
jol's Avatar
goose it depends on the lcd's maximum/minimum storage temps, check manual/data sheet. Most lcds have a higher storage temp than usage temp, so letting the car warm up the interior before turning on the screen is a good idea cold days
My cars
Old 12-30-2003, 01:45 AM   #15
robiewp's Avatar
get a security system with remote start that will turn the vehicle on if it drops below a certain temperature....
My LCD is good for -20C according to spec. want it?
Use the source, Luke.
car computer rev 3: 8" lilliput and usual suspects
robiewp is offline   Reply With Quote
