Dodge, why is that so funny? i knew the answer, because right after i posted that i ran the search function, and found the answer in like the 3 search result. its good to learn that the search function is there and how to use it.
Quote:
Imagine this, You have 2 boxes. One represents LCD screen. One represents LCD controller. They are linked together by a cable. The LCD controller box has an input. It could be RCA, S-Video or 15pin VGA. The LCD monitors you buy over the counter in a plastic casings have the LCD controllers built in. The "10" monitor w/ VGA" monitor ALREADY has the LCD controller built in. The VGA plug that you connect the PC to is a part of the LCD controller. If you would to buy an LCD from ebay, it doesn't come with a controller. You have the find a controller that'll work with that LCD screen. That's where your headache comes in. Basically an LCD screen is like a car's outer body, the doors, and windows and all. The LCD controller is the engine, transmission and the driveline.
the post was
Quote:
A nOOB question about monitors.
hope that helps you a little... is a decent explanation.
dodge, i dont know if your comment was a attack on me, or just funny because usually the more experienced guys tell the noobs to search... i never even have to post on this forum because i use the search function. anyways, sorry if i came off to strong, just wasn't sure which way to read ur comment.
