Hi guys, I'm having a little trouble deciding which Character display to go with for my upcoming carputer.
1) Parallel Character LCD 20x2 $20.33
* Green LED Backlight
* STN Positive, Gray
* Transflective
2) Parallel Character LCD 20x2 $19.92
* Yellow/Green LED Backlight
* STN Negative, Blue
* Transmissive
3) 20x2 PLED Module $23.75
Yellow-Green PLED display
These are all from the
Crystalfontz website. I was initally deciding between the two LCDs, however they now have a new so-called PLED display that displays yellow-green on black. It is a bit taller than the LCD displays, however it looks a bit nicer than those two.
From what I have read, the difference between the two LCDs is that the transflective display will have lower glare effect than transmissive when exposed to direct sunlight. I'm hoping that some of you guys that have LCDs of either type could tell me your experiences using similar displays in a car environment.
I know nothing about the PLED display other than it looks similar to the yellow-green/blue module. Does anyone know how this form of display would fare in sunlight and dark?
