Old 11-03-2003, 09:17 AM   #1
topache is on a distinguished road
Carputer Question ? Shuts down when starting my truck.
Hi,
I just installed over the weekend a cappucino pc in my truck using a inverter directly hooked up to my battery. The problem I'm running into is that when I start my truck the voltage drops to 7 or 8 volts which causes the inverter to beep and then my pc shuts down. How can I prevent this? I was thinking of a capacitor ? If so how big of a one do I need. All I want is to be able to keep the pc running while starting my truck. Any help would be greatly appreciated.
Thanks !!!
topache is offline   Reply With Quote
Old 11-03-2003, 09:32 AM   #2
wylie-c's Avatar
wylie-c is on a distinguished road
You really should have posted this in power supplies, but anyways, try searching for "tank circuit" in the power supplies section. It's a very common problem when using an inverter, and has been talked about a lot.
wylie-c is offline   Reply With Quote
Old 11-03-2003, 10:04 AM   #3
sorry about that. I'm kinda new in here. Thanks for the response. I'll do that.
Old 11-03-2003, 11:41 PM   #4
wylie-c's Avatar
Good luck! Btw, I have the same problem too, gotta build myself one!
