Quote: Originally Posted by pdsaab
I'm trying to use my sony xav-7w flip out screen in conjunction with this mini itx computer.
My original problem was when i was using the composite video wire, you are able to see all the loading screens up to the windows xp screen. as the windows desktop comes up, the screen starts to roll really fast and you cant see anything.
I tried using the a 75 ohm resistor. with that installed on the video wire. i get all the way to the windows xp screen again, and after that the screen goes blank for a minute or two, then the computer restarts on its own. Im pretty sure the display settings are 640 X 480 and refresh rate is 60hz.
please help before this computer ends up back on ebay.
thanks
pat
Err, is XP turning off the video out or changing the settings on you when it loads the desktop? Try pluggin it into a regular TV to see if you get the same problem just in case it's your flip out being extra picky. Check the display settings to make sure the composite video is still on and set to NTSC. It should be able to do 800x600 and maybe 1024x768 if they used a good converter chip.
DF
