Old 11-18-2003, 06:55 PM   #1
Registered User
Sh0cker's Avatar
Exclamation Allbrite lcd HELP
I want to know who's using Allbrite LCD and any of dicon controller boards.
Do you have to use powerstrip to set the resolution or it work fine for you.
For some reason i can't get the picture to fit my 10.4" lcd, because controller board sets it for 12" and picture is slightly bigger than my screen.
I know all chips are programmed the same way, how come im the only one who has this problem.
Please, let me know if you are using the same setup (allbrite lcd and dicon controller board) to solve my problem. Its really important.
Danny.
"If today was perfect, there would be no need for tomorrow."
My Car Project® ‹== !10.4" Allbrite, touchscreen, epia, 150opus, gps, wireless, sony remote [old] 128x64 Crystalfontz +double din [new]
Sh0cker is offline   Reply With Quote
Advertisement Sponsored links
Old 11-18-2003, 07:10 PM   #2
ddogg_777's Avatar
I had to change the dipswitches on mine...lcd1280ei
ddogg_777 is offline   Reply With Quote
Old 11-18-2003, 07:29 PM   #3
Registered User
Sh0cker's Avatar
what resolution did you get?
can you give me the pinout of the data cable
Danny.
Old 11-18-2003, 08:26 PM   #4
ddogg_777's Avatar
800x600. Do you have a datasheet for you controller? Email it to me.
What are you hoping to find with the pinout??
Old 11-18-2003, 08:44 PM   #5
Registered User
Sh0cker's Avatar
i want to compare the cable pinout
you're having this:
controller 30pin -> lcd 41pin
correct?
Danny.
Old 11-18-2003, 09:05 PM   #6
ddogg_777's Avatar
ACtually, only 27 of the 30 are going to the 41pin hirose. I guess a few of the grounds are connected together.
Old 11-18-2003, 09:11 PM   #7
ddogg_777's Avatar
There are only 2 pins that you need to worry about, the v and h syncs. All the others are power/ground and color.
Old 11-18-2003, 09:25 PM   #8
Registered User
Sh0cker's Avatar
only ddogg_777 has allbrite up and running?
Come on guys, help me out with this.
Danny.
Old 11-18-2003, 10:24 PM   #9
SinnerG's Avatar
Which Dicon controller are you using? If it's the LCD1024E, I too had to use powerstrip to get it to fit the screen. If it's the 1280EI, then it should fit perfectly.
SinnerG is offline   Reply With Quote
Old 11-18-2003, 10:30 PM   #10
Registered User
Sh0cker's Avatar
Ok, thats all i wanted to know.
I guess im not the only one ;d
Danny.
Old 11-18-2003, 10:53 PM   #11
I'm confused - if its 800 pixels across to complete a line
why does the controller need to be power stripped?
why should it treat the 12 inch screen different from the 10
speculating wildly- some number of pixel clock cycles of delay after a horz/nert sync pulse?
davesaudio2 is offline   Reply With Quote
Old 11-18-2003, 11:27 PM   #12
Registered User
Sh0cker's Avatar
"why should it treat the 12 inch screen different from the 10"
because the image is projected for 12" lcd and it only can be squeezed in by powrstrip to fit 100% in 10.4" lcd
If it was a resolution matter then why would they state for what size of the screen controller board is made? LCD is not ctr monitor...its treaded differently.
"speculating wildly- some number of pixel clock cycles of delay after a horz/nert sync pulse?"
I wish everything was that simple
Danny.
Old 11-18-2003, 11:45 PM   #13
ddogg_777's Avatar
Guys, a 6.5" vga screen will show the exact same image as a 12.1" vga screen because they are both 640x480. The only difference is that the larger lcd has larger pixels. It's all a matter of resolution and timing!
Did you test all the jumper settings I sent you?
Old 11-18-2003, 11:58 PM   #14
Registered User
Sh0cker's Avatar
Those are lcd1024E jumpers:
and those are yours lcd1280EI:
they are totally different, therefore its impossible to base my settings on yours.
Danny.
Old 11-19-2003, 12:22 AM   #15
yes, exactly my attempted point
however
if the controller setting says for eg 12inch and firmware assumes this 12 inch screen must be a 1024 screen so the controller scales the image from 800 to 1024
-that I can understand
