Old 11-24-2003, 10:51 AM   #1
Cheater2k is on a distinguished road
Lilliput screen native resolution
What is it peeps? Its the touch screen model from DSCUSTOMS.
Cheater2k is offline   Reply With Quote
Old 11-24-2003, 11:04 AM   #2
NJay's Avatar
NJay
800x480xRGB
Or if you want it normal LCD sales speak (i.e biggest numbers we can quote so that it looks good) its 2400x480
My CarPC install piccies http://www.celica-club.co.uk/cgi-bin...at=561&thumb=1
NJay is offline   Reply With Quote
Old 11-24-2003, 12:18 PM   #3
still seems a little streched u see, thats why im asking, any ideas?
Old 11-24-2003, 01:07 PM   #4
NJay's Avatar
NJay
It will be stretched if you are using std resolutions that a PC uses, eg. 640x480, 800x600, 1024x768. These are all 4:3 ratio resolutions. The lilliput will display them but much like a widescreen TV it will stretch them across the whole screen and hence will look fatter.
You need to setup you resolution so that is has roughly 16pixels across for every 9 pixels down, i.e 800x480 rather than 800x600 which is what I'd guess you're currently using.
HTH
Old 11-24-2003, 02:50 PM   #5
gwlund is on a distinguished road
Lilliput Resolutions
I got my Lilliput last week and spent Friday getting the thing setup. I got 1024x786 working but it looks to small. When I try 800x480 or 800x600 I get an "over range" message from the LCD. I tried sending the same resolutions to my desktop monitor and it works so I think my video card is sending the correct data.
Anyone have any words of wisdom. I'm using Powerstrip to set the custom resolutions.
gwlund is offline   Reply With Quote
Old 11-24-2003, 04:50 PM   #6
Raw Wave
Laidback's Avatar
Laidback is on a distinguished road
SEARCH for posts by "NJay", he seems to have done a lot of testing with different resolutions
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 11-25-2003, 01:08 PM   #7
Wizardtm is on a distinguished road
The only resolution that gives me a "almost" perfect 16:9 screen is 848x480@75hz.
First this resolution didn't work but after doing a reset (can be found in the menu of the lilliputscreen) it worked !
Wizardtm is offline   Reply With Quote
Old 01-15-2004, 10:21 AM   #8
zvi
zvi's Avatar
zvi is on a distinguished road
What Mobo/video are you using? I cant get this res on CLE266 (M10K onboard video), I am already ****ed off
zvi is offline   Reply With Quote
Lilliput screen + MKM1150 ¿? XaCoSo LCD/Display 6 11-15-2003 02:19 PM
Lilliput resolution? 16:9? detz LCD/Display 9 11-07-2003 04:05 AM
Lilliput internals - size of actual screen? - first post:) ScottC LCD/Display 4 10-25-2003 05:29 AM
Most common screen resolution? Wesson Newbie 5 10-16-2003 09:35 PM
Anyone know about Lilliput 7" XGA Touch Screen koyoutou LCD/Display 5 10-06-2003 12:37 AM
