Old 11-25-2003, 04:21 PM   #1
Registered User
big big liliput troubles.
working on my custom install i dismanteled my liliput an i managed to kill both white retaining clips that hold the band cable in place from the controller to the screen.
i enjoyed my screen for one day only.
what now ?????
time for the sig:
'00 VW golf TDI upped to 130 HP - 18" RS 6 wheels - liliput 7" tft in indash housing - epia 10K - SB audigy - caliber 1 fahrad CAP - RF punch amp - hollywood 1.6K mono amp - boston acoustics pro - RF 10" DVD sub
gerard is offline   Reply With Quote
Old 11-25-2003, 04:55 PM   #2
bosstone74's Avatar
what now ?????
Smoke some weed! that's what I'd dooooo!
BossTone74
bosstone74 is offline   Reply With Quote
Old 11-25-2003, 05:03 PM   #3
cvi
Ouch, tough luck. Take a bunch of pics and post them, maybe someone have good ideas what to do.
If not, we might prevent killing our own screen if we know what not to do when taking it apart. I planned on taking mine apart out of curiosity, but i think i will wait....
cvi is offline   Reply With Quote
Old 11-25-2003, 10:51 PM   #4
ddogg_777's Avatar
Retaining clips? How would that destroy it? Post pics so we better understand.
ddogg_777 is offline   Reply With Quote
Old 11-26-2003, 02:38 AM   #5
Registered User
ill try to shoot some tonight
the clips lock the band cable in place in the holder with the actual connections in it, without it wont position properly.
be very carefull when making them loose,the one on the motherboard slides to the side aproxx 3 mmto open, the one on the panel flips open 90 degrees to open.
time for the sig:
Old 11-26-2003, 04:07 AM   #6
For every problem there is a solution.....
Post some pictures and perhaps there is an easy solution for your problem.
Can't you use your soldering iron and some wires to reconnect te board?
Wizardtm is offline   Reply With Quote
Old 11-26-2003, 05:02 AM   #7
Registered User
there are about 50 wires in the cable, a hair thick and a hair apart so i dont think thats an option.
i can work very precise, have great equipment (electronic engeneer) but i think matters will go to worse.
i have a old 7" lcd with the same with connectors, i am going to try to modefy the connectors to fit those of the liliput ones.
also sent a desperate mail to cartft.com, maybe they can take some of a brokens screen or something.
time for the sig:
Old 11-29-2003, 10:32 PM   #8
kuo
kuo's Avatar
hey gerard,
i bought a liliput and i'm going to be dismantling it and putting the guts into a different enclosure. do you have an update on your situation? any advice?
thanks,
kuo
kuo is offline   Reply With Quote
Old 11-30-2003, 08:31 PM   #9
Hot Glue.... As long as you never want it back off again.
??? Worth a try.
Check back soon for the 7" Lilliput VGA USB Touchscreen for only $300! :D http://www.dscustoms.com
dscustoms is offline   Reply With Quote
Old 11-30-2003, 09:32 PM   #10
neuroplague's Avatar
I would try the hot glue option that dscustoms mentioned. A friend and I had the same problem with a xenarc screen a while back and the only way we could get the ribbon to stay in without the pressure from the clips was to insert the ribbon with the broken clip ... apply pressure and drown it in hot glue.... when we turned it on it worked fine, but never try to remove the glue because it might peel the circuit away from the board. ... You could also try the Digikey catalog www.digikey.com for a replcement ribbon connector. Good luck and I hope it works out.
neuroplague is offline   Reply With Quote
Old 11-30-2003, 09:43 PM   #11
Altimat's Avatar
I've fixed that problem before. The ribbon will center without the clip. You just need a thin plastic piece cut to wedge in with the ribbon, and secure with tape.
2002 Nissan Altima 3.5 5 Speed Bose FM/6CD ED E12A P4 2.26 512 Ram Ti4600 CDRW DVD Lilliput 200mW 802.11b Trackman AutoTap GPS Opus 150 Carnetix 1260
2005 Nissan Titan SE Dell GX-150 P3 1.0 512 Ram 20G GF4 MX4000 USB 2.0 DVD/RW Xenarc GPS Trackman
Altimat is offline   Reply With Quote
Old 12-01-2003, 05:28 PM   #12
Registered User
problem solved, i salvaged a clip from a broken ps2, cut it to fit between the connector and ribbon cable.
the positioning of the cable was a pita but iw works fine now in my indash housing
thx all for the suggestions
time for the sig:
Old 12-02-2003, 02:36 PM   #13
cvi
pictures?
How big is too big? infx708 LCD/Display 15 01-31-2005 06:58 PM
Question about BIG 8-pin DIN koyoutou Newbie 3 10-02-2003 04:56 AM
anything wrong with BIG? TiTUS General MP3Car Discussion 4 10-01-2003 03:06 PM
Liliput Vs Xenarc masterlp LCD/Display 1 09-25-2003 11:36 PM
how big is too big if you have got the room bryce_thomason LCD/Display 1 03-22-2003 11:40 AM
