Old 12-05-2003, 08:21 PM   #1
150watt inverter to run comp &lcd ?
Hi i'm just wondering wether the inverter with 2 things running off it will be to much. will it drain more power then the alternator is able to charge the battery ?
liquid85 is offline   Reply With Quote
Old 12-05-2003, 09:13 PM   #2
telekineticfool's Avatar
you'll need to be way more specific than that if you want any useful answers...might also want to check out the newbie section, as this post would fit in well there.
MP3 MR2 (click here for details)
Hardware: EPIA M10000, 512Meg Ram, 5.6"TFT, Opus 150watt DC-DC PSU
Software: Windows 2000, Media Engine 2.0
telekineticfool is offline   Reply With Quote
Old 12-06-2003, 02:38 AM   #3
fluffy2097's Avatar
a 150 watt inverter will easily be handled by the alternator. Don't worry about the battery.
As for your 2 things, Depends on what they are. If you're running a minifridge and an air conditioner, you will blow the fuse in the inverter. If you're running 2 strings of Xmas lights, you'll have no problem at all.
Personaly. I'd look on the 2 devices and find where it says how many watts they use. Then I'd add those 2 numbers together and see if it's more then 150 watts. I'd want 50-100 watts padding, for expansion uses.
A digital mind lost in an analog world.
Learn to ask smart questions!
http://www.catb.org/~esr/faqs/smart-questions.html
My car PC: The Lost Cause!
fluffy2097 is offline   Reply With Quote
Old 12-06-2003, 02:39 AM   #4
psyclobe's Avatar
christmas lights.... *chuckle*
psyclobe is offline   Reply With Quote
power problems while car is running.. TimW General Hardware Discussion 28 03-18-2006 10:11 PM
relay, inverter, fuse problems cheesyhoward Power Supplies 5 06-02-2005 10:04 AM
relay, inverter, fuse problems cheesyhoward General Hardware Discussion 6 06-22-2004 04:05 PM
How to keep the comp running when starting engine the_spy_guy Power Supplies 7 09-03-2002 07:33 PM
odd inverter behavior jshrieve General Hardware Discussion 30 04-10-2001 05:53 AM
