I've covered all the topics already started about this subject.. got the list of res's that NJay posted, tried them all.. no luck.
The problem is: No matter what res i select, there is always a flashing Line a few pixels high (2 it looks like) that flashes every few seconds, and the rest of the screen is black. It also looks like the screen itself is almost "pulsing" a bit.
I'm using an X-Micro GF4 Ti4200, with the LCD setup as secondary display using the DVI-out (using DVI->VGA Converter).
I'm running on Windows XP SP1, NVidia Detonators V45.23 (getting a little old i know)
Using powerstrip 3.30 build 364
Yes i have tried with the ports reversed (ie LCD on normal VGA port)
Yes i am only altering the secondary display which is the LCD.
Since i'm in AU and i got this imported from HK, i hooked the 12V rail from my PSU (Antec Solution Series 400W) up to the cigarette lighter adapter. Yes its the 12V rail and not the 5V one
Its a dodgy way of running it i know, but for the moment (just testing it etc) its ok.
So does anyone have any ideas why it is doing this? Is my vid-card to blame?
Also, the other two video in's work fine (tested using the output of my xbox and the PC video out).
Oh and on an unrelated topic.. does anyone know if the screen itself can display a 4:3 aspect ratio input without streching it to 16:9? Ie XBOX input?
thanks for your time guys.
