Old 12-10-2003, 04:04 AM   #1
Reactor is on a distinguished road
Lilliput 7" XGA VGA-IN Problems.. Yes i've searched already
I've covered all the topics already started about this subject.. got the list of res's that NJay posted, tried them all.. no luck.
The problem is: No matter what res i select, there is always a flashing Line a few pixels high (2 it looks like) that flashes every few seconds, and the rest of the screen is black. It also looks like the screen itself is almost "pulsing" a bit.
I'm using an X-Micro GF4 Ti4200, with the LCD setup as secondary display using the DVI-out (using DVI->VGA Converter).
I'm running on Windows XP SP1, NVidia Detonators V45.23 (getting a little old i know)
Using powerstrip 3.30 build 364
Yes i have tried with the ports reversed (ie LCD on normal VGA port)
Yes i am only altering the secondary display which is the LCD.
Since i'm in AU and i got this imported from HK, i hooked the 12V rail from my PSU (Antec Solution Series 400W) up to the cigarette lighter adapter. Yes its the 12V rail and not the 5V one Its a dodgy way of running it i know, but for the moment (just testing it etc) its ok.
So does anyone have any ideas why it is doing this? Is my vid-card to blame?
Also, the other two video in's work fine (tested using the output of my xbox and the PC video out).
Oh and on an unrelated topic.. does anyone know if the screen itself can display a 4:3 aspect ratio input without streching it to 16:9? Ie XBOX input?
thanks for your time guys.
Reactor is offline   Reply With Quote
Old 12-10-2003, 05:27 AM   #2
StratusPh34r's Avatar
StratusPh34r is on a distinguished road
Did you check the video refresh rate? Some LCDs don't like refresh rates higher that 60-75Hz.
StratusPh34r is offline   Reply With Quote
Old 12-10-2003, 06:02 AM   #3
sham is on a distinguished road
cut the connector off and wire it direct to the vga cable. the colours are all wrong (even on that wrx page -they no longer line up) on the new ones so youll have to trace them from the vga board itself to the bare wires and then from the other bare wires to the vga connector. mine worked at first then gave a similar flickering with no actual picture -so i redid the connector and its fine now.
sham is offline   Reply With Quote
Old 12-10-2003, 06:23 AM   #4
yes i checked the refresh rate. i tried from 60-85 with no luck.
I dont feel comfortable cutting off the connector without further input from other forum users as to what the problem is and how i could go about doing some testing to find out if the connector is at fault or not. Thanks for the input though.
Old 12-10-2003, 07:48 AM   #5
you have to look at that wrx site for how the 6 pin vga board goes to the 15 pin d sub vga connector and simply test for continuity (resistance of 0.0 sommet ohms) I cant remember the link but its all over this forum. If there was a dodgy output from your card youd get no signal or out of range or whatever- if its giving that then you are getting some signal to the horiz and vert refreshes (maybe 1 of them is not connected properly.) Certainly test em first as youll kick yourself for cutting it off when you find out its the power supply or lcd itself.
do you get a picture at all with the xbox? id test that -and the lcd with another pc. and do you get a menu still when its flickering-I didnt and it was the H synch and V synch pins not connected properly.
Old 12-11-2003, 05:04 AM   #6
hmm sounds interesting.
i searched for "wrx site" and didn't turn up anything. can you provide any more information to enable me to locate the link?
Old 12-11-2003, 06:18 AM   #7
http://www.tmz.com/wrx/lilliputLCD.html
Old 12-12-2003, 04:30 AM   #8
ah excellent! thanks
i'll get right on checking everything now.
Old 12-12-2003, 06:06 PM   #9
well after initial investigations using the info from that site, all the pins seem to be correctly connected. but i think more testing is in order.
To answer your othe question, yes the XBOX input via one of the RCA (Video 1 & 2) connectors works fantastically. Though the xbox output is in 4:3, and the screen stretches it to 16:9, so thats a tad annoying. Anyone know how to make a xbox use widescreen mode? LOL
Old 12-12-2003, 07:04 PM   #10
AutoTouch Creator
Gremlin's Avatar
Gremlin is on a distinguished road
Xbox 16:9
It's in the dashboard settings works awesome. The xbox in 16:9 is amazing!
Gremlin is offline   Reply With Quote
Old 12-12-2003, 07:12 PM   #11
hmm.. i'm using EvoX for my dash, so i dont know if that would support it.. but if the original MS Dash does.. EvoX should do too
Old 12-15-2003, 06:10 PM   #12
THanks for that Gremlin. Worked a treat. had to use the orig dash to change the setting however.. no problem though.
Still have the problem with the 2px line at the top of the VGA input though.. has anyone else seen this?
Old 01-11-2004, 06:04 PM   #13
z28control's Avatar
z28control is on a distinguished road
Same Problem
I am having the exact same problem with mine. If I connect the Lilliput to my Dell Desktop using the on-board VGA output the Lilliput works fine. Then I connect it to one of my Compaq laptops on the 15 Pin plug and I get the exact same results you get. One of the Laptops I use around the house and the other I cut in half and use for my CarPC. The home laptop was the first to be connected to the Lilliput. It worked at first but then I performed an auto-adjust and I have never seen a screen on the Lilliput from either of the laptops since. It still works great on my Dell. If I connect a standard VGA monitor to my laptops the output works great. I have used the monitor to set the refresh and res. settings to every setting I could on the laptops. (Most overlap with settings displayed with the Dell computer) I have not yet been able to figure this out. I have searched the posts for a solution with no luck. Have you found a solution yet?
CarPc- Compaq Presario 1200 x111 600Mhz AMD K-6(2) Win XP Pro
Trident Cyberblade Video Chipset (4MB Vid. Ram)
Home Laptop - Compaq Presario 2710 US 1000 Mhz P3 Win XP Home
Mobility Radion AGP Video Chipset (8MB Vid. Ram)
Dell Desk Top - Dell GXa 933 P3 Win XP Pro
Intel 82810E (4MB Vid. Ram)
Car PC - If you have to ask why, you'll never understand.
XAA289.com
z28control is offline   Reply With Quote
Old 01-11-2004, 11:00 PM   #14
z28control's Avatar
Pin #9???
I found something that works for my computers.(See reply above) I've noticed that typical monitor cables are usually missing PIN 9. I've done a little research and only found pinout diagrams for the 15 pin VGA. It is usually listed as "key" or "Not connected". Anyway I pulled the No. 9 Pin from my cable and my problem went away. If anyone knows why this may be please share. You could use an extension VGA cable to test your system. If it works for you also please let me know.
XAA289.com
Old 01-12-2004, 02:06 AM   #15
Ok, well i hadnt posted here about this since the last post cause i had forgotted i had started this thread :P
but anyway, i picked my self up a NEC Versa E400 laptop just before christmas, and the LCD works first go, no tweaking off the VGA out of the laptop, but still not off the PC's VGA out, so i was stoked!
Maybe they dont like GeForce's ? has anyone else tried running one of these puppies on a GeForce 4 Ti?
I just hope that the carputer's onboard videocard operates like the laptops.. cause then everything will be sweet.
Lilliput 7" VGA and EPIA M9000 issues... heat LCD/Display 9 01-15-2004 04:57 PM
Lilliput 619GL-70NP (XGA) withTouchscreen purchased in UK from carTFT.com russ LCD/Display 28 12-11-2003 08:26 AM
Anyone know about Lilliput 7" XGA Touch Screen koyoutou LCD/Display 5 10-06-2003 12:37 AM
Lilliput VGA 7" touch screen flick LCD/Display 35 10-01-2003 03:57 AM
what do peeple think to the lilliput 7" VGA Touch screen LCD? bertybassett LCD/Display 0 09-15-2003 07:44 PM
