Quote: Originally Posted by Audamn
found this link...haven't really researched it though.
http://www.holosport.com/holo.htm
I know it's for gauges, but it has a USB interface. Maybe it can be hacked up :P
Hi
I contacted holosport and got the following answer:
We currently plan on having the basic HoloSport( HUD ready for general
availability around January. It will be priced comparable to conventional
gauges at MSRP of $486. We are working on getting distributors up and
running. The basic system comes with Tachometer, Vacuum/Boost, Oil or Water
Temperature, Oil Pressure, and Volts. Also included is a programmable shift
light, a NOS arming and activation light. All of these functions can be
viewed at the same time or each separately.
Additional expansion cards w/ senders (included) will be available for $80
to $125 MSRP depending on the function. These include functions such as
speed, exhaust gas temp, air/fuel ratio, stereo amplifier temp, and NOS
level. There is a limit as to how many of these can be added because the
display gets crowded.
The dash unit measures 7"x7"x1-1/4" and we supply all the necessary senders
for universal installation. For the individual that wants to mount it flush
under the dash we have an under dash mounting system available. This of
course requires cutting a hole in the dash.
The image displays directly on the windshield but you need to apply our
clear proprietary film (supplied) for the best results. This is to eliminate
the distracting double image you often see when something is reflected off
of the dash onto the windshield. We condition the optical properties so that
you get a nice single crisp image of the display. We also have an optional
Tombstone display much like the fighter pilots have in their aircraft. These
are available for an additional $127.50 MSRP.
The unit will be available in three-color choices; green, red/orange, and
blue. It turns out that due to availability the only color available
initially will be the red/orange. We are having the web site updated to
reflect this. We have also designed and patented the system to work in
daylight. There are two settings because the light required for daylight
operation is to bright for nighttime use.
I hope this was informative and thanks for considering the HoloSport(
product.
Only US$ 486,well I think that I will try to make something myself or if I win the lotto buy the one from ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2447726718
