Old 12-12-2003, 01:44 AM   #1
BOND007BE's Avatar
BOND007BE
paint XENARC 7 inch
howdy ,
i own a xenarc 7 inch touchscreen ,
my question , i HATE the silver color , i want to paint it black.
any tips on opening xenarc and for painting it ?
tia
bond007
the sun always shine
BOND007BE is offline   Reply With Quote
Old 12-12-2003, 02:27 AM   #2
Raw Wave
Confused's Avatar
Confused is on a distinguished road
It's pretty simple to open up, just 6 screws. 1 in each corner on the back, plus 2 on the bottom edge (tiiiiny little silver ones that hold the mounting bracket)
Once you are inside, it's 2 screws to hold the controller board on (along the bottom edge) and then the screen/touchscreen overlay is held down by 4 screws, 2 on either side, which have little metal "clips" that go over the edge of the screen.
The buttons can then come out, they just pull out from the back, or push them from the front.
Re-installation is opposite of pulling it apart Just make sure you line up the touchscreen overlay and actual lcd panel in the centre of the gap
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 12-12-2003, 02:31 AM   #3
shchua
Quote: Originally Posted by BOND007BE
howdy ,
tia
bond007
I'm thinking of doing the same with my silver Lilliput screen. Opening it is really easy. I figured a can of black spray paint should work on the front and back housing, but how about the buttons ? The ones on the Lilliput are reverse silk-screened, the words are transparent and the buttons glow a cool blue when you press them. I could spray the buttons black and re-label them using Letraset adhesive lettering or similar, but I would lose the cool blue glow.
Any other ideas ?
shchua is offline   Reply With Quote
Old 12-12-2003, 03:05 AM   #4
BOND007BE's Avatar
BOND007BE
thanx for the info
about painting , just spray it over , or first sanding , primer and then final coat ?
Old 12-12-2003, 03:14 AM   #5
CelicaGarage
Use a primer designed for plastic parts. You definately DON'T want the paint to start flaking off.
Goto your paint shop and ask for plastic primer.
Vic
2000 Toyota Celica with Carputer
www.CelicaGarage.com
CelicaGarage is offline   Reply With Quote
Old 12-12-2003, 03:37 AM   #6
BOND007BE's Avatar
BOND007BE
before attaching primer do i need some sanding ? FINE
do you have a brand name for plastic primer ?
Old 12-12-2003, 04:06 AM   #7
Raw Wave
Confused's Avatar
It shouldn't need any sanding, just make sure you give it a good clean, to get rid of any finger prints or anything else
Just go to local shop and ask for a can of plastic primer, brand won't matter much at all
Garry
www.aimee.cc
Old 12-29-2003, 09:38 AM   #8
shchua
I just painted my Lilliput black using nothing more than a can of Tamiya TS-14. This is a synthetic lacquer specially formulated for use on plastic. There is NO need to apply plastic primer as the monitor already contains a coat of silver colored paint.
The monitor looks really nice in black - and the buttons look good and match well in their original silver color.
DigitalWWW TM-710VG vs. Xenarc 700YYV sq_geek LCD/Display 12 08-12-2003 10:14 PM
FS: Xenarc 700TSV touch UXGA capable cproaudio Classified Archive 16 01-20-2003 07:38 AM
Xenarc Meta FAQ Skippman LCD/Display 0 08-23-2002 04:11 PM
Xenarc 7" Touchscreen VGA Group Buy. Skippman LCD/Display 144 07-27-2002 11:52 AM
Removing paint sucks wizardPC Off Topic 3 07-01-2002 02:23 AM
