Old 12-12-2003, 08:12 AM   #1
bmzero is on a distinguished road
Regulate Power to LCD?
Do I need to regulate the power to my LCD? And if so, if there a piece of hardware somewhere that you recommend to do this?
I will be using a Xenarc touchscreen with a PIII laptop.
thanks in advance,
.brit
bmzero is offline   Reply With Quote
Old 12-12-2003, 09:19 AM   #2
Super Moderator
hijinks21's Avatar
hijinks21 is on a distinguished road
how are you planning on powering the laptop anyway?
'98 Explorer Sport
80% done
hijinks21 is offline   Reply With Quote
Old 12-13-2003, 01:00 AM   #3
I had originally planned on running a 12V source into the laptop, but I just checked the specs on the AC adapter for the laptop and it outputs 18V.
How do I get 18V from a 12V source without using a AC/DC converter?
Also, what do I use to regulate the power to the LCD?
thanks,
.brit
Old 12-13-2003, 01:49 PM   #4
NJay's Avatar
NJay
Use a cigarette lighter multivoltage Laptop adaptor which replaces the mains brick you normally plug into you laptop. If you want to install it permanatly then just unsolder the wire going to the lighter plug tip (12V+ positive) and surround (earth) and wire them into 12V+ and earth source in you car. I say only the tip and surround as most 12v -> 16/17/18/19V laptop adaptors have the electronics in the lighter plug
HTH
My CarPC install piccies http://www.celica-club.co.uk/cgi-bin...at=561&thumb=1
NJay is offline   Reply With Quote
Old 12-13-2003, 02:04 PM   #5
parawing742's Avatar
parawing742
I run my Xenarc screen unregulated, but I get tiny white flashes all over the screen when I do so. I working on a better solution right now.
Phillip Hullquist
I entertain people through adventure movies.
www.11visions.com
parawing742 is offline   Reply With Quote
Old 12-13-2003, 04:48 PM   #6
blicky_1's Avatar
blicky_1 is on a distinguished road
I am using two regulated psu's from Maplins, a 12v>15/16/17/18/19v adjustable for the laptop (£20) and a 12v for my Lilliput (£10). I checked both of these using a meter and putting the car under different loads see if voltage moved up/down too far, both were minimal. Both have been installed for over 6 weeks now with no problems. Both are using the original cig lighter ends, i have used female cig lighter sockets (£1 Maplins) to connect to battery and ignition lines. The screen psu switches on/off with the ignition key.
FYI the laptop psu has been left connected overnight sometimes with the laptop still running and car has started no problems. Makes me wonder if it is worth going the 12v/240v invertor route to install a full tower PC as the laptop was only supposed to be a temp measure!!
Regards
blicky_1
blicky_1 is offline   Reply With Quote
Old 12-14-2003, 05:25 AM   #7
NJay's Avatar
NJay
Blicky_1 which ones are they from maplins?
Old 12-15-2003, 08:06 AM   #8
Sources of power supplies?
Anyone know any good sources for adjustable DC power supplies online?
thanks,
.brit
Old 12-15-2003, 05:19 PM   #9
blicky_1's Avatar
N59AC LAPTOP Car ADAPTER now £14.99!
UG32K Universal DC Adaptor £9.99
Both are regulated and usually in stock
Old 12-15-2003, 06:34 PM   #10
Mr. Wiggles
shakes's Avatar
shakes is on a distinguished road
doesn't the xenarc come with a cig adapter to power it? that regulates the voltage right? just chop it up and hard wire it into another source.
My JeepPC Install
"there are no stupid questions, just stupid people."
"it's been agreed the whole world stinks so no one's taking showers anymore"
shakes is offline   Reply With Quote
Old 12-15-2003, 06:58 PM   #11
blicky_1's Avatar
Lilliput should have come with one but these but they were missing when shipped. You could cut off the plug as long as you fuse it (fuse is in the cig plug)
Old 06-10-2004, 11:29 AM   #12
Inuyasha is on a distinguished road
I got a used xenarc 700tsv but it came withuot the cig car adapter. What are my options to hardwire it?
Inuyasha is offline   Reply With Quote
LCD won't signal MB to power RCA out tropez LCD/Display 5 10-23-2003 04:13 PM
lcd power traitorhound LCD/Display 4 07-17-2003 05:44 PM
Doubt before buying an power acoustik lcd screen cyrofilho LCD/Display 5 06-01-2002 10:40 PM
LCD power question BRINET LCD/Display 3 04-20-2002 01:34 PM
LCD power, which pin? dudah85 General Hardware Discussion 1 05-10-2001 06:35 PM
