Old 01-02-2004, 12:29 PM   #16
Richie's Avatar
Thanks alot dude! Now it works perfectly... Now I'll just have to learn how to calibrate...
Quote: Originally Posted by Crav4Speed
Try these drivers:
http://www.egalax.com.tw/Download.htm
Here's the thread that started it:
Thread
You posted in there...
//Richie
My Nissan 200SX
Richie is offline   Reply With Quote
Old 03-01-2005, 08:30 PM   #17
Banned
RPM_VR4's Avatar
I cannot get my TouchKit to work. Please help!
History: When I first got it, I tested it a bit on my work PC and it was fine. After that it sat on a shelf for about 4 months while I was too busy to work on my CarPC. When I installed it in my CarPC, it was exibiting the current problem (below), but after trying about 10 different drivers I got from all over the place, I got it working most of the time (It would still exibit the current problem sometimes, but would fix its self after 5min or so). After about a month with it like that, my HDD crashed. After re-installing XP on a new HDD, I have never been able to get it to work in 3 months except twice it just started working for about 30 seconds and then started having the problem again.
Problem: 25 point cal is zig-zags all over the place, but mostly in the lower left corner. When I touch the screen on the right side, the pointer usually jumps somewhere in the middle, and then quickly flys over to the lower left corner. I have tried every driver I can find including digitalww's and the ones in this thread.
Do I need to replace the touch-screen material, the PCB, both, or can someone suggest a way to fix what I got?
Thanks,
-Ryan
RPM_VR4 is offline   Reply With Quote
Old 03-01-2005, 08:32 PM   #18
Banned
RPM_VR4's Avatar
Also, does it matter which way you connect the 4-pin from the plastic to the wire that goes to the PCB? I have tried both ways. It is currently the way on which it worked for 30 seconds those 2 times.
Lilliput LCD UK supplier -touch screen in stock now 001 LCD/Display 5 02-28-2004 12:45 PM
Lilliput VGA touch panel cracked. Would DigitalWW 7" touch panel fit ? shchua LCD/Display 2 12-11-2003 11:36 PM
Lilliput audio inputs/outputs Cinco5 LCD/Display 2 12-10-2003 03:54 PM
Lilliput composite input flashing? Misanthro LCD/Display 1 12-09-2003 04:58 PM
Lilliput ghost spectrumzz LCD/Display 9 11-26-2003 06:18 PM
